[postgis-tickets] [PostGIS] #4360: PostGIS upgrade tests shoudl fail and exit after first failure
PostGIS trac at osgeo.org
Thu Mar 28 09:41:09 PDT 2019
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.0.0
Component:  build/upgrade/install  |    Version:  trunk
 Keywords:                         |
 Dronie tests all upgrade paths and when she runs into a failure she
 continues on, but flags the job as failed.
 The issue is it's hard to tell where it failed unless you scroll thru the
 whole transcript.
 Would be better if upgrade steps just fail and exit without continuing on.
 That would serve 2 purposes
 1) Make it easier to see where the error is
 2) Less resource intensive, no point continuing when we have a crisis on
 our hands.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4360>
