[postgis-tickets] [PostGIS] #4360: PostGIS upgrade tests shoudl fail and exit after first failure
PostGIS trac at osgeo.org
Thu Mar 28 09:51:59 PDT 2019
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  medium                 |  Milestone:  PostGIS 3.0.0
 Component:  build/upgrade/install  |    Version:  trunk
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"17363" 17363]:
 #!CommitTicketReference repository="" revision="17363"
 Add -s switch to check_all_upgrades to stop on first failure
 Also have Dronie use that switch.
 Closes #4360
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4360#comment:1>
