[postgis-tickets] [PostGIS] #4359: FAIL: upgrade 2.5.0--3.0.0dev: function st_distance(geography, geography) is not unique
trac at osgeo.org
Fri Mar 29 07:04:59 PDT 2019
is not unique
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by strk):
It looks like the culprit could be r17300, which changed:
-CREATE OR REPLACE FUNCTION _ST_Distance(geography, geography, float8,
boolean)
+CREATE OR REPLACE FUNCTION ST_Distance(geog1 geography, geog2 geography,
use_spheroid boolean DEFAULT true)
Commit log theoretically moved things into legacy but evidently forgot to
add some in drop.sql
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4359#comment:3>
