[postgis-tickets] [PostGIS] #4359: FAIL: upgrade 2.5.0--3.0.0dev: function st_distance(geography, geography) is not unique
trac at osgeo.org
Fri Mar 29 07:07:32 PDT 2019
is not unique
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 3.0.0
Component: build/upgrade/install | Version: trunk
Resolution: | Keywords:
Comment (by strk):
In the postgis_reg database:
-[ RECORD 1
pg_get_functiondef | CREATE OR REPLACE FUNCTION
public.st_distance(geography, geography)
| RETURNS double precision
| LANGUAGE sql
| IMMUTABLE PARALLEL SAFE STRICT
| AS $function$SELECT public._ST_Distance($1, $2, 0.0,
true)$function$ +
-[ RECORD 2
pg_get_functiondef | CREATE OR REPLACE FUNCTION public.st_distance(geom1
geometry, geom2 geometry) +
| LANGUAGE c
| IMMUTABLE PARALLEL SAFE STRICT COST 10
| AS '$libdir/postgis-3',
$function$ST_Distance$function$
-[ RECORD 3
pg_get_functiondef | CREATE OR REPLACE FUNCTION public.st_distance(geog1
geography, geog2 geography, use_spheroid boolean DEFAULT true)+
| LANGUAGE c
$function$geography_distance$function$
-[ RECORD 4
pg_get_functiondef | CREATE OR REPLACE FUNCTION public.st_distance(text,
text) +
| LANGUAGE sql
| AS $function$ SELECT
public.ST_Distance($1::public.geometry, $2::public.geometry); $function$
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4359#comment:4>
