[postgis-tickets] r17369 - Fix postgis_type_name with (GEOMETRYM, 3)
Raul raul at rmr.ninja
Fri Mar 29 07:30:39 PDT 2019
Author: algunenano
Date: 2019-03-29 07:30:38 -0700 (Fri, 29 Mar 2019)
New Revision: 17369
   branches/2.3/NEWS
   branches/2.3/postgis/postgis.sql.in
   branches/2.3/regress/postgis_type_name.sql
   branches/2.3/regress/postgis_type_name_expected
Fix postgis_type_name with (GEOMETRYM,3)
Patch by Matt Bretl
References #4361
Modified: branches/2.3/NEWS
--- branches/2.3/NEWS	2019-03-29 14:29:21 UTC (rev 17368)
+++ branches/2.3/NEWS	2019-03-29 14:30:38 UTC (rev 17369)
@@ -1,3 +1,10 @@
+PostGIS 2.3.10
+2019/XX/XX
+  * Bug Fixes and Enchantments *
+  - #4361, Fix postgis_type_name with (GEOMETRYM,3) (Matt Bretl)
 PostGIS 2.3.9
 2019/03/11
Modified: branches/2.3/postgis/postgis.sql.in
--- branches/2.3/postgis/postgis.sql.in	2019-03-29 14:29:21 UTC (rev 17368)
+++ branches/2.3/postgis/postgis.sql.in	2019-03-29 14:30:38 UTC (rev 17369)
@@ -5213,89 +5213,91 @@
 	RETURNS varchar
 AS
- SELECT CASE WHEN $3 THEN new_name ELSE old_name END As geomname
+	SELECT CASE WHEN $3 THEN new_name ELSE old_name END As geomname
 	FROM
- 	( VALUES
- 		 ('GEOMETRY', 'Geometry', 2) ,
- 		 	('GEOMETRY', 'GeometryZ', 3) ,
- 		 	('GEOMETRY', 'GeometryZM', 4) ,
-			('GEOMETRYCOLLECTION', 'GeometryCollection', 2) ,
-			('GEOMETRYCOLLECTION', 'GeometryCollectionZ', 3) ,
-			('GEOMETRYCOLLECTIONM', 'GeometryCollectionM', 3) ,
-			('GEOMETRYCOLLECTION', 'GeometryCollectionZM', 4) ,
+	( VALUES
+			('GEOMETRY', 'Geometry', 2),
+			('GEOMETRY', 'GeometryZ', 3),
+			('GEOMETRYM', 'GeometryM', 3),
+			('GEOMETRY', 'GeometryZM', 4),
-			('POINT', 'Point',2) ,
-			('POINTM','PointM',3) ,
-			('POINT', 'PointZ',3) ,
-			('POINT', 'PointZM',4) ,
+			('GEOMETRYCOLLECTION', 'GeometryCollection', 2),
+			('GEOMETRYCOLLECTION', 'GeometryCollectionZ', 3),
+			('GEOMETRYCOLLECTIONM', 'GeometryCollectionM', 3),
+			('GEOMETRYCOLLECTION', 'GeometryCollectionZM', 4),
-			('MULTIPOINT','MultiPoint',2) ,
-			('MULTIPOINT','MultiPointZ',3) ,
-			('MULTIPOINTM','MultiPointM',3) ,
-			('MULTIPOINT','MultiPointZM',4) ,
+			('POINT', 'Point', 2),
+			('POINT', 'PointZ', 3),
+			('POINTM','PointM', 3),
+			('POINT', 'PointZM', 4),
-			('POLYGON', 'Polygon',2) ,
-			('POLYGON', 'PolygonZ',3) ,
-			('POLYGONM', 'PolygonM',3) ,
-			('POLYGON', 'PolygonZM',4) ,
+			('MULTIPOINT','MultiPoint', 2),
+			('MULTIPOINT','MultiPointZ', 3),
+			('MULTIPOINTM','MultiPointM', 3),
+			('MULTIPOINT','MultiPointZM', 4),
-			('MULTIPOLYGON', 'MultiPolygon',2) ,
-			('MULTIPOLYGON', 'MultiPolygonZ',3) ,
-			('MULTIPOLYGONM', 'MultiPolygonM',3) ,
-			('MULTIPOLYGON', 'MultiPolygonZM',4) ,
+			('POLYGON', 'Polygon', 2),
+			('POLYGON', 'PolygonZ', 3),
+			('POLYGONM', 'PolygonM', 3),
+			('POLYGON', 'PolygonZM', 4),
-			('MULTILINESTRING', 'MultiLineString',2) ,
-			('MULTILINESTRING', 'MultiLineStringZ',3) ,
-			('MULTILINESTRINGM', 'MultiLineStringM',3) ,
-			('MULTILINESTRING', 'MultiLineStringZM',4) ,
+			('MULTIPOLYGON', 'MultiPolygon', 2),
+			('MULTIPOLYGON', 'MultiPolygonZ', 3),
+			('MULTIPOLYGONM', 'MultiPolygonM', 3),
+			('MULTIPOLYGON', 'MultiPolygonZM', 4),
-			('LINESTRING', 'LineString',2) ,
-			('LINESTRING', 'LineStringZ',3) ,
-			('LINESTRINGM', 'LineStringM',3) ,
-			('LINESTRING', 'LineStringZM',4) ,
+			('MULTILINESTRING', 'MultiLineString', 2),
+			('MULTILINESTRING', 'MultiLineStringZ', 3),
+			('MULTILINESTRINGM', 'MultiLineStringM', 3),
+			('MULTILINESTRING', 'MultiLineStringZM', 4),
-			('CIRCULARSTRING', 'CircularString',2) ,
-			('CIRCULARSTRING', 'CircularStringZ',3) ,
-			('CIRCULARSTRINGM', 'CircularStringM',3) ,
-			('CIRCULARSTRING', 'CircularStringZM',4) ,
+			('LINESTRING', 'LineString', 2),
+			('LINESTRING', 'LineStringZ', 3),
+			('LINESTRINGM', 'LineStringM', 3),
+			('LINESTRING', 'LineStringZM', 4),
-			('COMPOUNDCURVE', 'CompoundCurve',2) ,
-			('COMPOUNDCURVE', 'CompoundCurveZ',3) ,
-			('COMPOUNDCURVEM', 'CompoundCurveM',3) ,
-			('COMPOUNDCURVE', 'CompoundCurveZM',4) ,
+			('CIRCULARSTRING', 'CircularString', 2),
+			('CIRCULARSTRING', 'CircularStringZ', 3),
+			('CIRCULARSTRINGM', 'CircularStringM' ,3),
+			('CIRCULARSTRING', 'CircularStringZM', 4),
-			('CURVEPOLYGON', 'CurvePolygon',2) ,
-			('CURVEPOLYGON', 'CurvePolygonZ',3) ,
-			('CURVEPOLYGONM', 'CurvePolygonM',3) ,
-			('CURVEPOLYGON', 'CurvePolygonZM',4) ,
+			('COMPOUNDCURVE', 'CompoundCurve', 2),
+			('COMPOUNDCURVE', 'CompoundCurveZ', 3),
+			('COMPOUNDCURVEM', 'CompoundCurveM', 3),
+			('COMPOUNDCURVE', 'CompoundCurveZM', 4),
-			('MULTICURVE', 'MultiCurve',2 ) ,
-			('MULTICURVE', 'MultiCurveZ',3 ) ,
-			('MULTICURVEM', 'MultiCurveM',3 ) ,
-			('MULTICURVE', 'MultiCurveZM',4 ) ,
+			('CURVEPOLYGON', 'CurvePolygon', 2),
+			('CURVEPOLYGON', 'CurvePolygonZ', 3),
+			('CURVEPOLYGONM', 'CurvePolygonM', 3),
+			('CURVEPOLYGON', 'CurvePolygonZM', 4),
-			('MULTISURFACE', 'MultiSurface', 2) ,
-			('MULTISURFACE', 'MultiSurfaceZ', 3) ,
-			('MULTISURFACEM', 'MultiSurfaceM', 3) ,
-			('MULTISURFACE', 'MultiSurfaceZM', 4) ,
+			('MULTICURVE', 'MultiCurve', 2),
+			('MULTICURVE', 'MultiCurveZ', 3),
+			('MULTICURVEM', 'MultiCurveM', 3),
+			('MULTICURVE', 'MultiCurveZM', 4),
-			('POLYHEDRALSURFACE', 'PolyhedralSurface',2) ,
-			('POLYHEDRALSURFACE', 'PolyhedralSurfaceZ',3) ,
-			('POLYHEDRALSURFACEM', 'PolyhedralSurfaceM',3) ,
-			('POLYHEDRALSURFACE', 'PolyhedralSurfaceZM',4) ,
+			('MULTISURFACE', 'MultiSurface', 2),
+			('MULTISURFACE', 'MultiSurfaceZ', 3),
+			('MULTISURFACEM', 'MultiSurfaceM', 3),
+			('MULTISURFACE', 'MultiSurfaceZM', 4),
-			('TRIANGLE', 'Triangle',2) ,
-			('TRIANGLE', 'TriangleZ',3) ,
-			('TRIANGLEM', 'TriangleM',3) ,
-			('TRIANGLE', 'TriangleZM',4) ,
+			('POLYHEDRALSURFACE', 'PolyhedralSurface', 2),
+			('POLYHEDRALSURFACE', 'PolyhedralSurfaceZ', 3),
+			('POLYHEDRALSURFACEM', 'PolyhedralSurfaceM', 3),
+			('POLYHEDRALSURFACE', 'PolyhedralSurfaceZM', 4),
+			('TRIANGLE', 'Triangle', 2),
+			('TRIANGLE', 'TriangleZ', 3),
+			('TRIANGLEM', 'TriangleM', 3),
+			('TRIANGLE', 'TriangleZM', 4),
 			('TIN', 'Tin', 2),
 			('TIN', 'TinZ', 3),
-			('TIN', 'TinM', 3),
+			('TINM', 'TinM', 3),
 			('TIN', 'TinZM', 4) )
 			 As g(old_name, new_name, coord_dimension)
-		WHERE (upper(old_name) = upper($1) OR upper(new_name) = upper($1))
-			AND coord_dimension = $2;
+	WHERE (upper(old_name) = upper($1) OR upper(new_name) = upper($1))
+		AND coord_dimension = $2;
 LANGUAGE 'sql' IMMUTABLE STRICT COST 200;
Modified: branches/2.3/regress/postgis_type_name.sql
--- branches/2.3/regress/postgis_type_name.sql	2019-03-29 14:29:21 UTC (rev 17368)
+++ branches/2.3/regress/postgis_type_name.sql	2019-03-29 14:30:38 UTC (rev 17369)
@@ -1,3 +1,15 @@
+SELECT 'GEOMETRY(0)', postgis_type_name('GEOMETRY', 0);
+SELECT 'GEOMETRY(1)', postgis_type_name('GEOMETRY', 1);
+SELECT 'GEOMETRY(2)', postgis_type_name('GEOMETRY', 2);
+SELECT 'GEOMETRY(3)', postgis_type_name('GEOMETRY', 3);
+SELECT 'GEOMETRY(4)', postgis_type_name('GEOMETRY', 4);
+SELECT 'GEOMETRY(5)', postgis_type_name('GEOMETRY', 5);
+SELECT 'GEOMETRYM(2)', postgis_type_name('GEOMETRYM', 2);
+SELECT 'GEOMETRYM(3)', postgis_type_name('GEOMETRYM', 3);
+SELECT 'GEOMETRYZ(3)', postgis_type_name('GEOMETRYZ', 3);
+SELECT 'GEOMETRYZM(3)', postgis_type_name('GEOMETRYZM', 3);
+SELECT 'GEOMETRYZM(4)', postgis_type_name('GEOMETRYZM', 4);
 SELECT 'POINT(0)', postgis_type_name('POINT', 0);
 SELECT 'POINT(1)', postgis_type_name('POINT', 1);
 SELECT 'POINT(2)', postgis_type_name('POINT', 2);
Modified: branches/2.3/regress/postgis_type_name_expected
--- branches/2.3/regress/postgis_type_name_expected	2019-03-29 14:29:21 UTC (rev 17368)
+++ branches/2.3/regress/postgis_type_name_expected	2019-03-29 14:30:38 UTC (rev 17369)
@@ -1,3 +1,14 @@
+GEOMETRY(0)|
+GEOMETRY(1)|
+GEOMETRY(2)|Geometry
+GEOMETRY(3)|GeometryZ
+GEOMETRY(4)|GeometryZM
+GEOMETRY(5)|
+GEOMETRYM(2)|
+GEOMETRYM(3)|GeometryM
+GEOMETRYZ(3)|GeometryZ
+GEOMETRYZM(3)|
+GEOMETRYZM(4)|GeometryZM
 POINT(0)|
 POINT(1)|
 POINT(2)|Point
