[postgis-tickets] r17370 - Topology documentation improvements
Raul raul at rmr.ninja
Fri Mar 29 08:46:38 PDT 2019
Author: algunenano
Date: 2019-03-29 08:46:38 -0700 (Fri, 29 Mar 2019)
New Revision: 17370
   trunk/doc/extras_topology.xml
   trunk/topology/README
   trunk/topology/TODO
   trunk/topology/topology.sql.in
Patch by François Bonzon
Closes https://github.com/postgis/postgis/pull/388
Modified: trunk/doc/extras_topology.xml
--- trunk/doc/extras_topology.xml	2019-03-29 14:30:38 UTC (rev 17369)
+++ trunk/doc/extras_topology.xml	2019-03-29 15:46:38 UTC (rev 17370)
@@ -25,7 +25,7 @@
 		<refentry id="getfaceedges_returntype">
 		  <refnamediv>
 			<refname>getfaceedges_returntype</refname>
-			<refpurpose>A composite type that consists of a sequence number and edge number.  This is the return type for <varname>ST_GetFaceEdges</varname></refpurpose>
+			<refpurpose>A composite type that consists of a sequence number and edge number.  This is the return type for <varname>ST_GetFaceEdges</varname>.</refpurpose>
 		  </refnamediv>
 		  <refsection>
 			<title>Description</title>
@@ -44,7 +44,7 @@
 		<refentry id="topogeometry">
 			  <refnamediv>
 				<refname>TopoGeometry</refname>
-				<refpurpose>A composite type representing a topologically defined geometry</refpurpose>
+				<refpurpose>A composite type representing a topologically defined geometry.</refpurpose>
 			  </refnamediv>
 			  <refsection>
@@ -93,7 +93,7 @@
 		<refentry id="validatetopology_returntype">
             <refnamediv>
                 <refname>validatetopology_returntype</refname>
-                    <refpurpose>A composite type that consists of an error message and id1 and id2 to denote location of error.  This is the return type for <varname>ValidateTopology</varname></refpurpose>
+                    <refpurpose>A composite type that consists of an error message and id1 and id2 to denote location of error.  This is the return type for <varname>ValidateTopology</varname>.</refpurpose>
                 </refnamediv>
             <refsection>
@@ -195,7 +195,7 @@
 		<refentry id="topoelementarray">
 		  <refnamediv>
 			<refname>TopoElementArray</refname>
-			<refpurpose>An array of TopoElement objects</refpurpose>
+			<refpurpose>An array of TopoElement objects.</refpurpose>
 		  </refnamediv>
 		  <refsection>
@@ -369,7 +369,8 @@
 			<!-- Optionally add a "See Also" section -->
 			<refsection>
 				<title>See Also</title>
-				<para></para>
+				<para><xref linkend="DropTopoGeometryColumn"/></para>
 			</refsection>
 		</refentry>
 		<refentry id="DropTopoGeometryColumn">
@@ -484,7 +485,7 @@
 			<refnamediv>
 				<refname>TopologySummary</refname>
-				<refpurpose>Takes a topology name and provides summary totals of types of objects in topology</refpurpose>
+				<refpurpose>Takes a topology name and provides summary totals of types of objects in topology.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -537,7 +538,7 @@
 			<refnamediv>
 				<refname>ValidateTopology</refname>
-				<refpurpose>Returns a set of validatetopology_returntype objects detailing issues with topology</refpurpose>
+				<refpurpose>Returns a set of validatetopology_returntype objects detailing issues with topology.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -893,7 +894,7 @@
 				<funcsynopsis>
 					<funcprototype>
 						<funcdef>integer <function>TopoGeo_AddPoint</function></funcdef>
-						<paramdef><type>varchar </type> <parameter>toponame</parameter></paramdef>
+						<paramdef><type>varchar </type> <parameter>atopology</parameter></paramdef>
 						<paramdef><type>geometry </type> <parameter>apoint</parameter></paramdef>
 						<paramdef choice="opt"><type>float8 </type> <parameter>tolerance</parameter></paramdef>
 					</funcprototype>
@@ -904,7 +905,7 @@
                 <para>
-Adds a point to an existing topology and return its identifier.
+Adds a point to an existing topology and returns its identifier.
 The given point will snap to existing nodes or edges within given tolerance.
 An existing edge may be split by the snapped point.
                 </para>
@@ -930,9 +931,7 @@
 			<refnamediv>
 				<refname>TopoGeo_AddLineString</refname>
-				<refpurpose>
-Adds a linestring to an existing topology using a tolerance and possibly splitting existing edges/faces. Returns edge identifiers
-				</refpurpose>
+				<refpurpose>Adds a linestring to an existing topology using a tolerance and possibly splitting existing edges/faces. Returns edge identifiers.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -939,7 +938,7 @@
 				<funcsynopsis>
 					<funcprototype>
 						<funcdef>SETOF integer <function>TopoGeo_AddLineString</function></funcdef>
 						<paramdef><type>geometry </type> <parameter>aline</parameter></paramdef>
 					</funcprototype>
@@ -950,7 +949,7 @@
                 <para>
-Adds a linestring to an existing topology and return a set of edge identifiers forming it up.
+Adds a linestring to an existing topology and returns a set of edge identifiers forming it up.
 The given line will snap to existing nodes or edges within given tolerance.
 Existing edges and faces may be split by the line.
                 </para>
@@ -976,18 +975,16 @@
 			<refnamediv>
 				<refname>TopoGeo_AddPolygon</refname>
-				<refpurpose>
-Adds a polygon to an existing topology using a tolerance and possibly splitting existing edges/faces.
-				</refpurpose>
+				<refpurpose>Adds a polygon to an existing topology using a tolerance and possibly splitting existing edges/faces. Returns face identifiers.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
 				<funcsynopsis>
 					<funcprototype>
-						<funcdef>integer <function>TopoGeo_AddPolygon</function></funcdef>
+						<funcdef>SETOF integer <function>TopoGeo_AddPolygon</function></funcdef>
 						<paramdef><type>geometry </type> <parameter>apoly</parameter></paramdef>
-						<paramdef choice="opt"><type>float8 </type> <parameter>atolerance</parameter></paramdef>
+						<paramdef choice="opt"><type>float8 </type> <parameter>tolerance</parameter></paramdef>
 					</funcprototype>
 				</funcsynopsis>
 			</refsynopsisdiv>
@@ -996,7 +993,7 @@
                 <para>
-Adds a polygon to an existing topology and return a set of face identifiers forming it up.
+Adds a polygon to an existing topology and returns a set of face identifiers forming it up.
 The boundary of the given polygon will snap to existing nodes or edges within given tolerance.
 Existing edges and faces may be split by the boundary of the new polygon.
                 </para>
@@ -1051,8 +1048,8 @@
                 <para>Adds an isolated node with point location <varname>apoint</varname> to an existing face with faceid <varname>aface</varname> to a topology <varname>atopology</varname> and returns the nodeid of the new node.</para>
-                <para>If the spatial reference system (srid) of the point geometry is not the same as the topology, the <varname>apoint</varname> is not a point geometry, the point is null, or the point intersects an existing edge (even at the boundaries) then an exception is thrown. If the point already
-                    exists as a node, an exception is thrown. </para>
+                <para>If the spatial reference system (srid) of the point geometry is not the same as the topology, the <varname>apoint</varname> is not a point geometry, the point is null, or the point intersects an existing edge
+                    (even at the boundaries) then an exception is thrown. If the point already exists as a node, an exception is thrown.</para>
                 <para>If <varname>aface</varname> is not null and the <varname>apoint</varname> is not within the face, then an exception is thrown.</para>
                 <!-- use this format if new function -->
@@ -1097,9 +1094,9 @@
                 <para>Adds an isolated edge defined by geometry <varname>alinestring</varname> to a topology connecting two existing isolated nodes <varname>anode</varname> and <varname>anothernode</varname> and returns the edge id of the new edge.</para>
-                <para>If the spatial reference system (srid) of the <varname>alinestring</varname> geometry is not the same as the topology, any of the input arguments are null,   or the nodes are contained in more than one face, or the nodes are start or end nodes of an existing edge,
-                    then an exception is thrown. </para>
-                <para>If the <varname>alinestring</varname> is not within the face of the face the <varname>anode</varname> and <varname>anothernode</varname> belong to, then an exception is thrown. </para>
+                <para>If the spatial reference system (srid) of the <varname>alinestring</varname> geometry is not the same as the topology, any of the input arguments are null, or the nodes are contained in more than one face, or the nodes are start or end nodes of an existing edge,
+                    then an exception is thrown.</para>
+                <para>If the <varname>alinestring</varname> is not within the face of the face the <varname>anode</varname> and <varname>anothernode</varname> belong to, then an exception is thrown.</para>
                 <para>If the <varname>anode</varname> and <varname>anothernode</varname> are not the start and end points of the <varname>alinestring</varname> then an exception is thrown.</para>
@@ -1524,7 +1521,7 @@
 				<refname>ST_ModEdgeHeal</refname>
 				<refpurpose>
-Heal two edges by deleting the node connecting them, modifying the first edge
+Heals two edges by deleting the node connecting them, modifying the first edge
 and deleting the second edge. Returns the id of the deleted node.
 				</refpurpose>
 			</refnamediv>
@@ -1544,7 +1541,7 @@
                 <para>
 Updates all existing joined edges and relationships accordingly.
@@ -1571,7 +1568,7 @@
 				<refname>ST_NewEdgeHeal</refname>
 				<refpurpose>
-Heal two edges by deleting the node connecting them, deleting both edges,
+Heals two edges by deleting the node connecting them, deleting both edges,
 and replacing them with an edge whose direction is the same as the first
 edge provided.
 				</refpurpose>
@@ -1592,7 +1589,7 @@
                 <para>
 edge provided.
 Returns the id of the new edge replacing the healed ones.
@@ -1838,7 +1835,7 @@
           <refnamediv>
             <refname>GetEdgeByPoint</refname>
-            <refpurpose>Find the edge-id of an edge that intersects a given point</refpurpose>
+            <refpurpose>Finds the edge-id of an edge that intersects a given point.</refpurpose>
           </refnamediv>
           <refsynopsisdiv>
@@ -1847,7 +1844,7 @@
                 <funcdef>integer <function>GetEdgeByPoint</function></funcdef>
-                <paramdef><type>float8 </type> <parameter>tol</parameter></paramdef>
+                <paramdef><type>float8 </type> <parameter>tol1</parameter></paramdef>
               </funcprototype>
             </funcsynopsis>
@@ -1854,15 +1851,16 @@
           </refsynopsisdiv>
           <refsection>
-            <title>Retrieve the id of an edge that intersects a Point</title>
+            <title>Description</title>
+            <para>Retrieves the id of an edge that intersects a Point.</para>
             <para>The function returns an integer (id-edge) given a topology, a POINT and a tolerance. If tolerance = 0 then the point has to intersect the edge.</para>
-            <para>If the point doesn't intersect an edge, returns 0 (zero).</para>
+            <para>If <varname>apoint</varname> doesn't intersect an edge, returns 0 (zero).</para>
             <para>If use tolerance > 0 and there is more than one edge near the point then an exception is thrown.</para>
             <note>
-              <para>If tolerance = 0, the function use ST_Intersects otherwise uses ST_DWithin.</para>
+              <para>If tolerance = 0, the function uses ST_Intersects otherwise uses ST_DWithin.</para>
             </note>
             <para>Performed by the GEOS module.</para>
             <para>Availability: 2.0.0</para>
@@ -1900,7 +1898,7 @@
         <refentry id="GetFaceByPoint">
 		<refnamediv>
 			<refname>GetFaceByPoint</refname>
-			<refpurpose>Find the face-id of a face that intersects a given point</refpurpose>
+			<refpurpose>Finds the face-id of a face that intersects a given point.</refpurpose>
 		</refnamediv>
 		<refsynopsisdiv>
 			<funcsynopsis>
@@ -1908,15 +1906,16 @@
 					<funcdef>integer <function>GetFaceByPoint</function></funcdef>
 				</funcprototype>
 			</funcsynopsis>
 		</refsynopsisdiv>
 		<refsection>
-                <title>Description</title>
-			<para>Retrieve the id of a face that intersects a Point.</para>
+			<para>Retrieves the id of a face that intersects a Point.</para>
 			<para>The function returns an integer (id-face) given a topology, a POINT and a tolerance. If tolerance = 0 then the point has to intersect the face.</para>
-			<para>If the point doesn't intersect a face, returns 0 (zero).</para>
+			<para>If <varname>apoint</varname> doesn't intersect a face, returns 0 (zero).</para>
 			<para>If use tolerance > 0 and there is more than one face near the point then an exception is thrown.</para>
 			<note>
@@ -1954,7 +1953,7 @@
           <refnamediv>
             <refname>GetNodeByPoint</refname>
-            <refpurpose>Find the id of a node at a point location</refpurpose>
+            <refpurpose>Finds the node-id of a node at a point location.</refpurpose>
           </refnamediv>
           <refsynopsisdiv>
@@ -1962,8 +1961,8 @@
               <funcprototype>
                 <funcdef>integer <function>GetNodeByPoint</function></funcdef>
-                <paramdef><type>geometry </type> <parameter>point</parameter></paramdef>
+                <paramdef><type>geometry </type> <parameter>apoint</parameter></paramdef>
               </funcprototype>
             </funcsynopsis>
@@ -1970,13 +1969,14 @@
           </refsynopsisdiv>
           <refsection>
-            <title>Retrieve the id of a node at a point location</title>
-            <para>The function return an integer (id-node) given a topology, a POINT and a tolerance. If tolerance = 0 mean exactly intersection otherwise retrieve the node from an interval.</para>
-            <para>If there isn't a node at the point, it return 0 (zero).</para>
-            <para>If use tolerance > 0 and near the point there are more than one node it throw an exception.</para>
+            <para>Retrieves the id of a node at a point location.</para>
+            <para>The function returns an integer (id-node) given a topology, a POINT and a tolerance. If tolerance = 0 means exact intersection, otherwise retrieves the node from an interval.</para>
+            <para>If <varname>apoint</varname> doesn't intersect a node, returns 0 (zero).</para>
+            <para>If use tolerance > 0 and there is more than one node near the point then an exception is thrown.</para>
             <note>
-              <para>If tolerance = 0, the function use ST_Intersects otherwise will use ST_DWithin.</para>
             </note>
@@ -2398,7 +2398,7 @@
 		<refentry id="TopologyPolygonize">
 			<refnamediv>
 				<refname>Polygonize</refname>
-				<refpurpose>Find and register all faces defined by topology edges</refpurpose>
+				<refpurpose>Finds and registers all faces defined by topology edges.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
 				<funcsynopsis>
@@ -2412,7 +2412,7 @@
 			<refsection>
-                <para>Register all faces that can be built out a topology edge primitives.</para>
+                <para>Registers all faces that can be built out a topology edge primitives.</para>
                 <para>The target topology is assumed to contain no self-intersecting edges.</para>
                 <note><para>Already known faces are recognized, so it is safe to call Polygonize multiple times on the same topology.</para></note>
 		<note><para>
@@ -2561,9 +2561,7 @@
 			<refnamediv>
 				<refname>AddFace</refname>
-				<refpurpose>
-Registers a face primitive to a topology and gets its identifier.
-        </refpurpose>
+				<refpurpose>Registers a face primitive to a topology and gets its identifier.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -2679,8 +2677,8 @@
 		<funcsynopsis>
 		  <funcprototype>
 			<funcdef>geometry <function>ST_Simplify</function></funcdef>
-			<paramdef><type>TopoGeometry</type> <parameter>geomA</parameter></paramdef>
-			<paramdef><type>float</type> <parameter>tolerance</parameter></paramdef>
+			<paramdef><type>TopoGeometry</type> <parameter>tg</parameter></paramdef>
+			<paramdef><type>float8</type> <parameter>tolerance</parameter></paramdef>
 		  </funcprototype>
 		</funcsynopsis>
 	  </refsynopsisdiv>
@@ -2742,8 +2740,8 @@
 			<refsection>
-                <para>Creates a topogeometry object for layer denoted by layer_id and registers it in the relations table in the <varname>toponame</varname> schema.</para>
-                <para>tg_type is an integer: 1:[multi]point (punctal), 2:[multi]line (lineal), 3:[multi]poly (areal), 4:collection. layer_id is the layer id in the topology.layer table.</para>
+                <para>Creates a topogeometry object for layer denoted by <varname>layer_id</varname> and registers it in the relations table in the <varname>toponame</varname> schema.</para>
+                <para><varname>tg_type</varname> is an integer: 1:[multi]point (punctal), 2:[multi]line (lineal), 3:[multi]poly (areal), 4:collection. <varname>layer_id</varname> is the layer id in the topology.layer table.</para>
                 <para>punctal layers are formed from set of nodes, lineal layers are formed from a set of edges, areal layers are formed from a set of faces,
 	and collections can be formed from a mixture of nodes, edges, and faces.</para>
                 <para>Omitting the array of components generates an empty TopoGeometry object.</para>
@@ -2833,9 +2831,7 @@
 			<refnamediv>
 				<refname>toTopoGeom</refname>
-				<refpurpose>
-Converts a simple Geometry into a topo geometry
-        </refpurpose>
+				<refpurpose>Converts a simple Geometry into a topo geometry.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -2960,7 +2956,7 @@
 		<refentry id="TopoElementArray_Agg">
           <refnamediv>
             <refname>TopoElementArray_Agg</refname>
-            <refpurpose>Returns a <varname>topoelementarray</varname> for a set of element_id, type arrays (topoelements)</refpurpose>
+            <refpurpose>Returns a <varname>topoelementarray</varname> for a set of element_id, type arrays (topoelements).</refpurpose>
           </refnamediv>
           <refsynopsisdiv>
@@ -3009,7 +3005,7 @@
 			<refnamediv>
 				<refname>clearTopoGeom</refname>
-				<refpurpose>Clears the content of a topo geometry</refpurpose>
+				<refpurpose>Clears the content of a topo geometry.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -3054,7 +3050,7 @@
     <refentry id="TopoGeom_addElement">
 			<refnamediv>
 				<refname>TopoGeom_addElement</refname>
-				<refpurpose>Add an element to the definition of a TopoGeometry</refpurpose>
+				<refpurpose>Adds an element to the definition of a TopoGeometry.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
 				<funcsynopsis>
@@ -3100,7 +3096,7 @@
 			<refnamediv>
 				<refname>TopoGeom_remElement</refname>
-				<refpurpose>Remove an element from the definition of a TopoGeometry</refpurpose>
+				<refpurpose>Removes an element from the definition of a TopoGeometry.</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -3145,12 +3141,12 @@
     <refentry id="toTopoGeom_editor_proxy">
 			<refnamediv>
-				<refpurpose>Adds a geometry shape to an existing topo geometry</refpurpose>
+				<refpurpose>Adds a geometry shape to an existing topo geometry.</refpurpose>
 			</refnamediv>
 			<refsection>
 <para>
-Refer to <xref linkend="toTopoGeom" />
+Refer to <xref linkend="toTopoGeom" />.
 </para>
       </refsection>
     </refentry>
@@ -3165,7 +3161,7 @@
 			<refnamediv>
 				<refname>GetTopoGeomElementArray</refname>
-				<refpurpose>Returns a <varname>topoelementarray</varname> (an array of topoelements) containing the topological elements and type of the given TopoGeometry (primitive elements)</refpurpose>
+				<refpurpose>Returns a <varname>topoelementarray</varname> (an array of topoelements) containing the topological elements and type of the given TopoGeometry (primitive elements).</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -3213,7 +3209,7 @@
 			<refnamediv>
 				<refname>GetTopoGeomElements</refname>
-				<refpurpose>Returns a set of <varname>topoelement</varname> objects containing the topological  element_id,element_type of the given TopoGeometry (primitive elements)</refpurpose>
+				<refpurpose>Returns a set of <varname>topoelement</varname> objects containing the topological element_id,element_type of the given TopoGeometry (primitive elements).</refpurpose>
 			</refnamediv>
 			<refsynopsisdiv>
@@ -3610,10 +3606,7 @@
         <refnamediv>
           <refname>Intersects</refname>
-          <refpurpose>
-Returns true if any pair of primitives from the
-two topogeometries intersect.
-          </refpurpose>
+          <refpurpose>Returns true if any pair of primitives from the two topogeometries intersect.</refpurpose>
         </refnamediv>
         <refsynopsisdiv>
Modified: trunk/topology/README
--- trunk/topology/README	2019-03-29 14:30:38 UTC (rev 17369)
+++ trunk/topology/README	2019-03-29 15:46:38 UTC (rev 17370)
@@ -22,7 +22,7 @@
 =Building
   To build the topology support:
   $ make
 =Testing
@@ -40,7 +40,7 @@
 	It will create a 'topology' schema in <your_postgis_enabled_db>
 	hosting all the topology functions. To be run with db-owner perms.
 	Remember to grant execute to users.
 To uninstall:
 	$ psql -c 'drop schema topology cascade'
@@ -79,7 +79,7 @@
 ==Destroying a topology
 To destroy a topology:
 	SELECT topology.DropTopology(<name>);
 ==Loading topology data
@@ -98,8 +98,8 @@
 	 * left_face integer REFERENCES Face.face_id
 	 * right_face integer REFERENCES Face.face_id
 	 * geom geometry ( a linestring )
 	* Node
 	 * node_id integer PRIMARY KEY
 	 * containing_face integer REFERENCES Face.face_id
@@ -152,7 +152,7 @@
 (composed by TopoGeometries from the child_layer).
 Once the layer is created (it's id is returned by the AddTopoGeometryColumn
-function) you're ready to construct TopoGeometry objects in it:
+function) you're ready to construct TopoGeometry objects in it:
   	topology.CreateTopoGeom(
@@ -173,7 +173,7 @@
 For Hierarchical TopoGeometry objects this would be:
-	{{child_layer_id, topogeoemtry_id}, ...}
+	{{child_layer_id, topogeometry_id}, ...}
 ==Converting Geometry to TopoGeometry while populating the topology
@@ -211,7 +211,7 @@
 ==ST_GetFaceGeometry() implementation
-The ST_GetFaceGeometry() function is currently implemented
+The ST_GetFaceGeometry() function is currently implemented
 as a call to polygonize() receiving all edges with the
 given Face on the left or right side. This reduces the number
 of SQL queries to 1, but makes it hard to detect any
@@ -229,7 +229,7 @@
 Face geometries might also be cached, but that might still
 be slower then overloading the predicates.
-==Topology table constraints
+==Topology table constraints
 In addition to the constraints defined in SQL/MM specification,
 this implementation adds constraints to enforce Node and Edge
Modified: trunk/topology/TODO
--- trunk/topology/TODO	2019-03-29 14:30:38 UTC (rev 17369)
+++ trunk/topology/TODO	2019-03-29 15:46:38 UTC (rev 17370)
@@ -8,7 +8,7 @@
 # 2.1.13.3 - Named Spatial Relationship predicates based on the DE-9IM
 + intersects -- support Hierarchical geometries
-* equals
+* equals
 - disjoint
 - touches
 - crosses
@@ -17,4 +17,4 @@
 - contains
 - relate
-# Geomery editing
+# Geometry editing
Modified: trunk/topology/topology.sql.in
--- trunk/topology/topology.sql.in	2019-03-29 14:30:38 UTC (rev 17369)
+++ trunk/topology/topology.sql.in	2019-03-29 15:46:38 UTC (rev 17370)
@@ -353,7 +353,7 @@
 -- When used to define _hierarchical_ TopoGeometries,
 -- element_type will be the child layer identifier and
--- element_id will be composing TopoGoemetry identifier
+-- element_id will be composing TopoGeometry identifier
 CREATE DOMAIN topology.TopoElement AS integer[]
   CONSTRAINT DIMENSIONS CHECK (
