[postgis-tickets] r17371 - Fix various misspellings of "geometry"
Raul
raul at rmr.ninja
Fri Mar 29 08:56:44 PDT 2019
Author: algunenano
Date: 2019-03-29 08:56:43 -0700 (Fri, 29 Mar 2019)
New Revision: 17371
trunk/doc/po/ja/reference_processing.xml.po
trunk/doc/reference_accessor.xml
trunk/doc/reference_editor.xml
trunk/doc/reference_processing.xml
trunk/extras/history_table/history_table.sql
trunk/extras/ogc_test_suite/1_schema.sql
trunk/liblwgeom/liblwgeom.h.in
trunk/loader/README.pgsql2shp
trunk/regress/core/sql-mm-compoundcurve.sql
Patch by François Bonzon
Closes https://github.com/postgis/postgis/pull/389
Modified: trunk/doc/po/ja/reference_processing.xml.po
--- trunk/doc/po/ja/reference_processing.xml.po 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/doc/po/ja/reference_processing.xml.po 2019-03-29 15:56:43 UTC (rev 17371)
@@ -2672,7 +2672,7 @@
msgid ""
"Returns a set of geometry_dump (geom,path) rows of all points that make up a "
"geometry."
-msgstr "ジオメトリを作る全ての点のgometry_dump(geom,path)行の集合を返します。"
+msgstr "ジオメトリを作る全ての点のgeometry_dump(geom,path)行の集合を返します。"
#. Tag: funcprototype
#: reference_processing.xml:1021
Modified: trunk/doc/reference_accessor.xml
--- trunk/doc/reference_accessor.xml 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/doc/reference_accessor.xml 2019-03-29 15:56:43 UTC (rev 17371)
@@ -2151,7 +2151,7 @@
<para>>Return the 1-based Nth geometry (face) if the geometry is a
POLYHEDRALSURFACE, POLYHEDRALSURFACEM.
Otherwise, return NULL. This returns the same answer as ST_GeometryN for Polyhedral Surfaces.
- Using ST_GemoetryN is faster.</para>
+ Using ST_GeometryN is faster.</para>
<note>
<para>Index is 1-based.</para>
@@ -2265,19 +2265,21 @@
(3 rows)
--Example circular string
-SELECT ST_AsText(ST_PointN(ST_GeomFromText('CIRCULARSTRING(1 2, 3 2, 1 2)'),2));
+SELECT ST_AsText(ST_PointN(ST_GeomFromText('CIRCULARSTRING(1 2, 3 2, 1 2)'), 2));
-st_astext
-POINT(3 2)
+ st_astext
+ POINT(3 2)
+(1 row)
-SELECT st_astext(f)
-FROM ST_GeometryFromtext('LINESTRING(0 0 0, 1 1 1, 2 2 2)') as g
- ,ST_PointN(g, -2) AS f -- 1 based index
+SELECT ST_AsText(f)
+FROM ST_GeomFromText('LINESTRING(0 0 0, 1 1 1, 2 2 2)') AS g
+ ,ST_PointN(g, -2) AS f; -- 1 based index
-st_astext
-"POINT Z (1 1 1)"
+ st_astext
+ POINT Z (1 1 1)
+(1 row)
</programlisting>
</refsection>
Modified: trunk/doc/reference_editor.xml
--- trunk/doc/reference_editor.xml 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/doc/reference_editor.xml 2019-03-29 15:56:43 UTC (rev 17371)
@@ -1504,7 +1504,7 @@
<title>Description</title>
<para>
- Snaps the vertices and segments of a geometry
+ Snaps the vertices and segments of a geometry to
another Geometry's vertices.
A snap distance tolerance is used to control where snapping is performed.
The result geometry is the input geometry with the vertices snapped.
@@ -1573,7 +1573,6 @@
( 51 150, 101 150, 76 175, 51 150 )),
(( 151 100, 151 200, 176 175, 151 100 )))') As poly,
ST_GeomFromText('LINESTRING (5 107, 54 84, 101 100)') As line
) As foo;
polysnapped
@@ -1601,7 +1600,6 @@
) As foo;
polysnapped
Modified: trunk/doc/reference_processing.xml
--- trunk/doc/reference_processing.xml 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/doc/reference_processing.xml 2019-03-29 15:56:43 UTC (rev 17371)
@@ -3603,11 +3603,11 @@
<para>Filters away vertex points based on their m-value. Returns a geometry with only
vertex points that have a m-value larger or equal to the min value and smaller or equal to
the max value. If max-value argument is left out only min value is considered. If fourth argument is left out the m-value
- will not be in the resulting geoemtry. If resulting geometry have too few vertex points left for its geometry type an empty
- geoemtry will be returned. In a geometry collection
+ will not be in the resulting geometry. If resulting geometry have too few vertex points left for its geometry type an empty
+ geometry will be returned. In a geometry collection
geometries without enough points will just be left out silently. If </para>
<para>This function is mainly intended to be used in conjunction with ST_SetEffectiveArea. ST_EffectiveArea sets the effective area
- of a vertex in it's m-value. With ST_FilterByM it then is possible to get a simplified version of the geoemtry without any calculations, just by filtering</para>
+ of a vertex in it's m-value. With ST_FilterByM it then is possible to get a simplified version of the geometry without any calculations, just by filtering</para>
<note><para>There is a difference in what ST_SimplifyVW returns when not enough points meets the creterias compared to ST_FilterByM.
ST_SimplifyVW returns the geometry with enough points while ST_FilterByM returns an empty geometry</para></note>
Modified: trunk/extras/history_table/history_table.sql
--- trunk/extras/history_table/history_table.sql 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/extras/history_table/history_table.sql 2019-03-29 15:56:43 UTC (rev 17371)
@@ -226,6 +226,6 @@
/*TODO LIST:
-CREATE A FUNCTION THAT WILL DROP A CERTAIN HISTORIC TABLE AND REMOVE ITS ITENS FROM GEOMERTY_COLUMNS AND HISTORIC_INFORMATION
-CREATE A FUNCTION TO POPULATE ALL THE EXISTING RECORDS TO THE HISTORIC TABLE, AS A INSERT
\ No newline at end of file
+CREATE A FUNCTION THAT WILL DROP A CERTAIN HISTORIC TABLE AND REMOVE ITS ITEMS FROM GEOMETRY_COLUMNS AND HISTORIC_INFORMATION
+CREATE A FUNCTION TO POPULATE ALL THE EXISTING RECORDS TO THE HISTORIC TABLE, AS AN INSERT
Modified: trunk/extras/ogc_test_suite/1_schema.sql
--- trunk/extras/ogc_test_suite/1_schema.sql 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/extras/ogc_test_suite/1_schema.sql 2019-03-29 15:56:43 UTC (rev 17371)
@@ -508,7 +508,7 @@
-- POPULATE GEOMETRY AND FEATURE TABLES
-- *** ADAPTATION ALERT ***
--- This script DOES NOT make any inserts into a GEOMTERY_COLUMNS table/view.
+-- This script DOES NOT make any inserts into a GEOMETRY_COLUMNS table/view.
-- Implementers should insert whatever makes this happen in their implementation
-- below. Furthermore, the inserts below may be replaced by whatever mechanism
-- may be provided by implementers to insert rows in feature tables such that
Modified: trunk/liblwgeom/liblwgeom.h.in
--- trunk/liblwgeom/liblwgeom.h.in 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/liblwgeom/liblwgeom.h.in 2019-03-29 15:56:43 UTC (rev 17371)
@@ -2061,8 +2061,8 @@
#define TWKB_BBOX 0x01 /* User wants bboxes */
#define TWKB_SIZE 0x02 /* User wants sizes */
#define TWKB_ID 0x04 /* User wants id */
-#define TWKB_NO_TYPE 0x10 /* No type because it is a sub geoemtry */
-#define TWKB_NO_ID 0x20 /* No ID because it is a subgeoemtry */
+#define TWKB_NO_TYPE 0x10 /* No type because it is a sub geometry */
+#define TWKB_NO_ID 0x20 /* No ID because it is a subgeometry */
#define TWKB_DEFAULT_PRECISION 0 /* Aim for 1m (or ft) rounding by default */
Modified: trunk/loader/README.pgsql2shp
--- trunk/loader/README.pgsql2shp 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/loader/README.pgsql2shp 2019-03-29 15:56:43 UTC (rev 17371)
@@ -53,8 +53,8 @@
this will reduce the likelihood of coordinate drift due to con-
version to and from WKT format. Coordinate drifts will not occur
with PostGIS 1.0.0 and newer versions. It will be slightly
- faster, but might fail if any NON-gemetry column lacks a cast to
- text.
+ faster, but might fail if any NON-geometry column lacks a cast
+ to text.
-r Raw mode. Do not drop the gid field, or escape column names.
Modified: trunk/regress/core/sql-mm-compoundcurve.sql
--- trunk/regress/core/sql-mm-compoundcurve.sql 2019-03-29 15:46:38 UTC (rev 17370)
+++ trunk/regress/core/sql-mm-compoundcurve.sql 2019-03-29 15:56:43 UTC (rev 17371)
@@ -159,10 +159,10 @@
2 0,
0 0))');
-SELECT 'astext01', ST_Astext(the_geom_2d) FROM public.compoundcurve;
-SELECT 'astext02', ST_Astext(the_geom_3dm) FROM public.compoundcurve;
-SELECT 'astext03', ST_Astext(the_geom_3dz) FROM public.compoundcurve;
-SELECT 'astext04', ST_Astext(the_geom_4d) FROM public.compoundcurve;
+SELECT 'astext01', ST_AsText(the_geom_2d) FROM public.compoundcurve;
+SELECT 'astext02', ST_AsText(the_geom_3dm) FROM public.compoundcurve;
+SELECT 'astext03', ST_AsText(the_geom_3dz) FROM public.compoundcurve;
+SELECT 'astext04', ST_AsText(the_geom_4d) FROM public.compoundcurve;
SELECT 'asewkt01', ST_Asewkt(the_geom_2d) FROM public.compoundcurve;
SELECT 'asewkt02', ST_Asewkt(the_geom_3dm) FROM public.compoundcurve;
