[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0alpha2-133-g78f61fb
git at osgeo.org
git at osgeo.org
Tue Nov 3 05:49:58 PST 2020
the project "PostGIS".
via 78f61fb1be3bffd05ffe6e01e40ed68f7191097c (commit)
via b13e16d62780bf8acccbdaee973e55f010f2299d (commit)
from 873d3e5a099dff60614be54c65657eebab184e80 (commit)
revisions in full, below.
commit 78f61fb1be3bffd05ffe6e01e40ed68f7191097c
Author: Sandro Santilli <strk at kbt.io>
Date: Tue Nov 3 14:49:10 2020 +0100
Do not let Travis run tests in parallel
It's not supported, and makes reading logs an hell anyway
diff --git a/ci/travis/run_tests.sh b/ci/travis/run_tests.sh
index bad7a77..36a34ec 100644
--- a/ci/travis/run_tests.sh
+++ b/ci/travis/run_tests.sh
@@ -16,4 +16,5 @@ export CUNIT_VALGRIND_FLAGS="--leak-check=full --error-exitcode=1"
# Standard build
./configure CFLAGS="${CFLAGS_STD}" LDFLAGS="${LDFLAGS_STD}"
-bash ./ci/travis/logbt -- make -j check RUNTESTFLAGS=--verbose
+bash ./ci/travis/logbt -- make -j
+bash ./ci/travis/logbt -- make check RUNTESTFLAGS=--verbose
commit b13e16d62780bf8acccbdaee973e55f010f2299d
Date: Tue Nov 3 14:48:56 2020 +0100
Allow running core regress tests without sfcgal
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 2fe6a9b..ef65ec0 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -194,7 +194,7 @@ include regress/loader/tests.mk
include regress/dumper/tests.mk
ifeq ($(HAVE_SFCGAL),yes)
override RUNTESTFLAGS := $(RUNTESTFLAGS) --sfcgal
- include regress/sfcgal/tests.mk
+ include sfcgal/regress/tests.mk
endif
ifeq (@TOPOLOGY@,topology)
override RUNTESTFLAGS := $(RUNTESTFLAGS) --topology
diff --git a/configure.ac b/configure.ac
index a82d8c3..bcbc7cd 100644
--- a/configure.ac
+++ b/configure.ac
@@ -1579,6 +1579,7 @@ AC_OUTPUT([GNUmakefile
postgis/Makefile
postgis/sqldefines.h
sfcgal/Makefile
+ sfcgal/regress/Makefile
loader/Makefile
loader/cunit/Makefile
topology/Makefile
@@ -1588,7 +1589,6 @@ AC_OUTPUT([GNUmakefile
regress/core/tests.mk
regress/dumper/Makefile
regress/loader/Makefile
- regress/sfcgal/Makefile
doc/Makefile
doc/Makefile.comments
doc/html/image_src/Makefile
diff --git a/regress/Makefile.in b/regress/Makefile.in
index e05bc23..c1449f3 100644
--- a/regress/Makefile.in
+++ b/regress/Makefile.in
@@ -48,10 +48,6 @@ check-unit:
include core/tests.mk
include loader/tests.mk
include dumper/tests.mk
-ifeq ($(HAVE_SFCGAL),yes)
- override RUNTESTFLAGS := $(RUNTESTFLAGS) --sfcgal
- include sfcgal/tests.mk
-endif
include runtest.mk
@@ -64,7 +60,6 @@ distclean: clean
rm -f core/Makefile
rm -f loader/Makefile
rm -f dumper/Makefile
- rm -f sfcgal/Makefile
staged-install-sfcgal:
@if test x"@SFCGAL@" != "x"; then \
diff --git a/sfcgal/Makefile.in b/sfcgal/Makefile.in
index 9455981..7c39b00 100644
--- a/sfcgal/Makefile.in
+++ b/sfcgal/Makefile.in
@@ -161,6 +161,7 @@ uninstall_sfcgal.sql: sfcgal.sql ../utils/create_undef.pl
distclean: clean
rm -f Makefile
+ rm -f regress/Makefile
check-unit:
diff --git a/regress/sfcgal/Makefile.in b/sfcgal/regress/Makefile.in
similarity index 94%
rename from regress/sfcgal/Makefile.in
rename to sfcgal/regress/Makefile.in
index 687f73a..e120ec2 100644
--- a/regress/sfcgal/Makefile.in
+++ b/sfcgal/regress/Makefile.in
@@ -17,6 +17,6 @@ override RUNTESTFLAGS := $(RUNTESTFLAGS) --sfcgal
topsrcdir = $(realpath ../../)
include tests.mk
-include ../runtest.mk
+include ../../regress/runtest.mk
check: check-regress
diff --git a/regress/sfcgal/README b/sfcgal/regress/README
similarity index 100%
rename from regress/sfcgal/README
rename to sfcgal/regress/README
diff --git a/regress/sfcgal/approximatemedialaxis.sql b/sfcgal/regress/approximatemedialaxis.sql
rename from regress/sfcgal/approximatemedialaxis.sql
rename to sfcgal/regress/approximatemedialaxis.sql
diff --git a/regress/sfcgal/approximatemedialaxis_expected b/sfcgal/regress/approximatemedialaxis_expected
rename from regress/sfcgal/approximatemedialaxis_expected
rename to sfcgal/regress/approximatemedialaxis_expected
diff --git a/regress/sfcgal/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
rename from regress/sfcgal/regress_sfcgal.sql
rename to sfcgal/regress/regress_sfcgal.sql
diff --git a/regress/sfcgal/regress_sfcgal_expected b/sfcgal/regress/regress_sfcgal_expected
rename from regress/sfcgal/regress_sfcgal_expected
rename to sfcgal/regress/regress_sfcgal_expected
diff --git a/regress/sfcgal/tests.mk b/sfcgal/regress/tests.mk
rename from regress/sfcgal/tests.mk
rename to sfcgal/regress/tests.mk
Summary of changes:
GNUmakefile.in | 2 +-
ci/travis/run_tests.sh | 3 ++-
configure.ac | 2 +-
regress/Makefile.in | 5 -----
sfcgal/Makefile.in | 1 +
{regress/sfcgal => sfcgal/regress}/Makefile.in | 2 +-
{regress/sfcgal => sfcgal/regress}/README | 0
{regress/sfcgal => sfcgal/regress}/approximatemedialaxis.sql | 0
{regress/sfcgal => sfcgal/regress}/approximatemedialaxis_expected | 0
{regress/sfcgal => sfcgal/regress}/regress_sfcgal.sql | 0
{regress/sfcgal => sfcgal/regress}/regress_sfcgal_expected | 0
{regress/sfcgal => sfcgal/regress}/tests.mk | 0
12 files changed, 6 insertions(+), 9 deletions(-)
rename {regress/sfcgal => sfcgal/regress}/Makefile.in (94%)
rename {regress/sfcgal => sfcgal/regress}/README (100%)
rename {regress/sfcgal => sfcgal/regress}/approximatemedialaxis.sql (100%)
rename {regress/sfcgal => sfcgal/regress}/approximatemedialaxis_expected (100%)
rename {regress/sfcgal => sfcgal/regress}/regress_sfcgal.sql (100%)
rename {regress/sfcgal => sfcgal/regress}/regress_sfcgal_expected (100%)
rename {regress/sfcgal => sfcgal/regress}/tests.mk (100%)
hooks/post-receive
