[postgis-tickets] [SCM] PostGIS branch master updated. 3.1.0rc1-467-g8dae80e
Tue Aug 31 14:55:38 PDT 2021
the project "PostGIS".
       via  8dae80e404a9c63e6e79e707d8e1f568f49fe077 (commit)
       via  1e113c67250d998e8e5a6954ba80bffd2e467d62 (commit)
      from  a1c99b2dbb13e657321e9044190187e2d48771db (commit)
revisions in full, below.
commit 8dae80e404a9c63e6e79e707d8e1f568f49fe077
Merge: a1c99b2 1e113c6
Author: Regina Obe <lr at pcorp.us>
Date:   Tue Aug 31 17:55:32 2021 -0400
    Merge remote-tracking branch 'bjornharrtell/patch-1'
commit 1e113c67250d998e8e5a6954ba80bffd2e467d62
Author: Björn Harrtell <bjornharrtell at users.noreply.github.com>
Date:   Tue Aug 31 20:24:46 2021 +0200
    Add section about debug requirements and tips
diff --git a/README.postgis b/README.postgis
index a0e4b73..24fdc9c 100644
--- a/README.postgis
+++ b/README.postgis
@@ -170,6 +170,31 @@ Final lines of output contain a summary of test results: run, succeeded,
 failed. If you have any failure please file a bug report using the online bug
 tracker: http://trac.osgeo.org/postgis/report/3
+DEBUGGING
+The normal build and testing procedure might not be enough for development and
+debugging as that requires a debug build of PostgreSQL and other proper compilation
+flags throughout. A way to get such an environment is to use the same docker images
+as the PostGIS CI setup and that can be done on a *nix host by first running this
+in a cloned postgis repository to later get core dump log output:
+> sudo bash ./ci/travis/logbt --setup
+Then you can run the following to get a docker container up and running with the
+correct requirements already in place and the postgis repository (at /postgis)
+mounted into it:
+> docker run -it --mount type=bind,source=/postgis,target=/src/postgis \
+postgis/postgis-build-env:pg13-geos39-gdal31-proj71 /bin/bash
+And finally the following command inside the container will build and run all the
+postgis tests:
+> bash ./ci/travis/run_usan_gcc.sh
+You can make customized versions of `run_usan_gcc.sh` to run only specific tests
+and skip redundant steps.
 INSTALLATION
Summary of changes:
 README.postgis | 25 +++++++++++++++++++++++++
 1 file changed, 25 insertions(+)
hooks/post-receive
