[postgis-tickets] [PostGIS] #3231: ST_RemoveIsoNode does not prevent removal of nodes used in TopoGeometry objects
PostGIS trac at osgeo.org
Wed Jul 14 12:29:26 PDT 2021
objects
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS Fund Me
 Component:  topology  |    Version:  2.0.x
Resolution:            |   Keywords:
Description changed by strk:
Old description:
> I've noticed that there's no check preventing ST_RemoveIsoNode from
> removing nodes that are used in TopoGeometry definitions. It should, to
> be consistent with the rest of the "destructive" primitive operations.
New description:
 removing nodes that are used in TopoGeometry definitions. It should, to be
 See also #3248 and #3239
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3231#comment:6>
