[postgis-tickets] [PostGIS] #3239: ST_{Mod, New}EdgeHeal does not check for TopoGeometry defined by removed node
PostGIS trac at osgeo.org
Wed Jul 14 12:29:59 PDT 2021
#3239: ST_{Mod,New}EdgeHeal does not check for TopoGeometry defined by removed
node
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.0.4
 Component:  topology  |    Version:  2.1.x
Resolution:            |   Keywords:
Description changed by strk:
Old description:
> Reading the code I don't think we're checking for the node being removed
> by edge healing operations to be used in the definition of a
> TopoGeometry. We should !
> This is to be checked first, but pretty sure it's the case.
> NOTE: there's no 2.2.1 milestone to assign to tickets.
New description:
 by edge healing operations to be used in the definition of a TopoGeometry.
 We should !
 See also #3248 and #3231
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3239#comment:12>
