[postgis-tickets] [PostGIS] #4326: Circular strings distances are wrong
trac at osgeo.org
Mon Jul 26 13:34:55 PDT 2021
Reporter: komzpa | Owner: strk
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.5.3
Component: postgis | Version: 2.4.x
Resolution: | Keywords:
Comment (by pramsey):
The right answer pops out when it's just a point/line distance, so the
problem must line in the containment test.
WITH data AS (
SELECT
'CIRCULARSTRING(7874821 8715927,8907663 8715927,8844683
7750316,7937800 7750316,7874821 8715927)'::geometry AS a,
'POINT(5433865 8243495)'::geometry AS b
SELECT ST_Distance(a, b), a && b AS bbox_intersect FROM data;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/4326#comment:8>
