[SCM] PostGIS branch master updated. 3.4.0rc1-1212-gccf4b1932
Tue Jun 18 05:36:17 PDT 2024
the project "PostGIS".
       via  ccf4b19329eb87c2b12f794e4884c3a84dbfe10a (commit)
      from  ef4e8b8965e7e9070c3378cd442abf8bfdbd46bc (commit)
revisions in full, below.
commit ccf4b19329eb87c2b12f794e4884c3a84dbfe10a
Author: DeepL <noreply-mt-deepl at weblate.org>
Date:   Tue Jun 18 12:35:35 2024 +0000
    Translated PostGIS Manual using Weblate (French)
    Currently translated at 99.6% (5686 of 5707 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 0461996a2..b6dc24547 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -8,8 +8,8 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2024-03-14 17:56+0000\n"
-"PO-Revision-Date: 2024-06-18 12:35+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"PO-Revision-Date: 2024-06-18 12:36+0000\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "postgis-manual/fr/>\n"
 "Language: fr\n"
@@ -29160,6 +29160,8 @@ msgid ""
 "This function does not preserve boundaries shared between polygons. Use "
 "<xref linkend=\"ST_CoverageSimplify\"/> if this is required."
 msgstr ""
+"Cette fonction ne préserve pas les limites partagées entre les polygones. "
+"Utilisez <xref linkend=\"ST_CoverageSimplify\"/> si cela est nécessaire."
 #. Tag: para
 #, no-c-format
@@ -29170,6 +29172,8 @@ msgstr "Un cercle trop simplifié devient un triangle, moyennement un octogone,"
 #, no-c-format
 msgid "Simplifying a set of lines. Lines may intersect after simplification."
 msgstr ""
+"Simplification d'un ensemble de lignes. Les lignes peuvent se croiser après "
+"simplification."
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/fr/postgis-manual.po | 8 ++++++--
 1 file changed, 6 insertions(+), 2 deletions(-)
hooks/post-receive
