[SCM] PostGIS branch master updated. 3.4.0rc1-1214-g0c54fb5cc
git at osgeo.org
git at osgeo.org
Tue Jun 18 05:39:33 PDT 2024
the project "PostGIS".
via 0c54fb5cc6eaf4c5eb1f21784151d3df1bad855f (commit)
via c432b3d8a5c615b15b02372bb94e8898317cb7e8 (commit)
from ccf4b19329eb87c2b12f794e4884c3a84dbfe10a (commit)
revisions in full, below.
commit 0c54fb5cc6eaf4c5eb1f21784151d3df1bad855f
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Jun 18 12:37:32 2024 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 99.7% (5690 of 5707 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index bd56ca1e0..2c2b1d552 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-03-14 17:56+0000\n"
"PO-Revision-Date: 2024-06-18 12:39+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -29179,6 +29179,8 @@ msgstr ""
#, no-c-format
msgid "Simplifying a MultiPolygon. Polygonal results may be invalid."
msgstr ""
+"Simplification d'un polygone multiple. Les résultats polygonaux peuvent être "
+"invalides."
#. Tag: para
#, no-c-format
@@ -29187,6 +29189,9 @@ msgid ""
"linkend=\"ST_SimplifyVW\"/>, <xref linkend=\"ST_CoverageSimplify\"/>, "
"Topology <xref linkend=\"TP_ST_Simplify\"/>"
msgstr ""
+", <xref linkend=\"ST_SimplifyPreserveTopology\"/>, <xref linkend="
+"\"ST_SimplifyVW\"/>, <xref linkend=\"ST_CoverageSimplify\"/>, Topologie "
+"<xref linkend=\"TP_ST_Simplify\"/>"
#. Tag: refpurpose
#, no-c-format
@@ -29194,6 +29199,8 @@ msgid ""
"Returns a simplified and valid representation of a geometry, using the "
"Douglas-Peucker algorithm."
msgstr ""
+"Renvoie une représentation simplifiée et valide d'une géométrie, en "
+"utilisant l'algorithme de Douglas-Peucker."
#. Tag: para
#, no-c-format
@@ -29207,6 +29214,15 @@ msgid ""
"are within the tolerance distance of the simplified linework, as long as "
"topology is preserved. The result will be valid and simple if the input is."
msgstr ""
+"Calcule une représentation simplifiée d'une géométrie en utilisant une "
+"variante de l'algorithme <link xlink:href=\"https://en.wikipedia.org/wiki/"
+"Ramer%E2%80%93Douglas%E2%80%93Peucker_algorithm\">Douglas-Peucker</link> qui "
+"limite la simplification pour s'assurer que le résultat a la même topologie "
+"que l'entrée. La <varname>tolérance</varname> de simplification est une "
+"valeur de distance, dans les unités du SRS d'entrée. La simplification "
+"supprime les sommets qui se trouvent à l'intérieur de la distance de "
+"tolérance du réseau simplifié, pour autant que la topologie soit préservée. "
+"Le résultat sera valide et simple si l'entrée est."
#. Tag: para
#, no-c-format
commit c432b3d8a5c615b15b02372bb94e8898317cb7e8
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date: Tue Jun 18 12:36:14 2024 +0000
index b6dc24547..bd56ca1e0 100644
@@ -8,8 +8,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 12:36+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 12:39+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
"Language: fr\n"
@@ -29172,8 +29172,8 @@ msgstr "Un cercle trop simplifié devient un triangle, moyennement un octogone,"
#, no-c-format
msgid "Simplifying a set of lines. Lines may intersect after simplification."
msgstr ""
-"Simplification d'un ensemble de lignes. Les lignes peuvent se croiser après "
-"simplification."
+"Simplification d'un ensemble de lignes. Les lignes peuvent s'intersecter "
+"après simplification."
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/fr/postgis-manual.po | 22 +++++++++++++++++++---
1 file changed, 19 insertions(+), 3 deletions(-)
hooks/post-receive
