[SCM] PostGIS branch master updated. 3.4.0rc1-1219-ga8d61bf14
git at osgeo.org
git at osgeo.org
Tue Jun 18 05:43:14 PDT 2024
the project "PostGIS".
via a8d61bf1460ff955a4519f3693945894ab0fbe19 (commit)
via 74fb15e718f5f23865b59e2ab928ebf96714d3dc (commit)
from f98a6baa8356932e723a3539522ac5d2769fdd2a (commit)
revisions in full, below.
commit a8d61bf1460ff955a4519f3693945894ab0fbe19
Author: DeepL <noreply-mt-deepl at weblate.org>
Date: Tue Jun 18 12:42:27 2024 +0000
Translated PostGIS Manual using Weblate (French)
Currently translated at 99.8% (5697 of 5707 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/fr/
diff --git a/doc/po/fr/postgis-manual.po b/doc/po/fr/postgis-manual.po
index 7c32876a1..0ca54de65 100644
--- a/doc/po/fr/postgis-manual.po
+++ b/doc/po/fr/postgis-manual.po
@@ -9,7 +9,7 @@ msgstr ""
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2024-03-14 17:56+0000\n"
"PO-Revision-Date: 2024-06-18 12:43+0000\n"
-"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
+"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
"Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
"postgis-manual/fr/>\n"
"Language: fr\n"
@@ -29393,6 +29393,8 @@ msgid ""
"Returns a simplified representation of a geometry, using the Visvalingam-"
"Whyatt algorithm"
msgstr ""
+"Renvoie une représentation simplifiée d'une géométrie, en utilisant "
+"l'algorithme de Visvalingam-Whyatt"
#. Tag: para
#, no-c-format
@@ -29405,6 +29407,13 @@ msgid ""
"\"corners\" with area less than the tolerance. The result may not be valid "
"even if the input is."
msgstr ""
+"Renvoie une représentation simplifiée d'une géométrie à l'aide de "
+"l'algorithme <link xlink:href=\"https://en.wikipedia.org/wiki/"
+"Visvalingam%E2%80%93Whyatt_algorithm\">Visvalingam-Whyatt</link>. La "
+"<varname>tolérance</varname> de simplification est une valeur de surface, "
+"dans les unités du SRS d'entrée. La simplification supprime les sommets qui "
+"forment des \"coins\" dont la surface est inférieure à la tolérance. Le "
+"résultat peut ne pas être valide même si l'entrée l'est."
#. Tag: para
#, no-c-format
commit 74fb15e718f5f23865b59e2ab928ebf96714d3dc
Author: Thomas Muguet <thomas.muguet at oslandia.com>
Date: Tue Jun 18 12:42:09 2024 +0000
index d90ca34b6..7c32876a1 100644
@@ -8,8 +8,8 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
-"PO-Revision-Date: 2024-06-18 12:42+0000\n"
-"Last-Translator: DeepL <noreply-mt-deepl at weblate.org>\n"
+"PO-Revision-Date: 2024-06-18 12:43+0000\n"
+"Last-Translator: Thomas Muguet <thomas.muguet at oslandia.com>\n"
"Language: fr\n"
@@ -29272,14 +29272,15 @@ msgstr ""
#, no-c-format
msgid "Simplifying a MultiPolygon, preserving topology of shells and holes."
msgstr ""
-"Simplification d'un multipolygone, en préservant la topologie des coques et "
-"des trous."
+"Simplification d'un multipolygone, en préservant la topologie des coquilles "
+"et des trous."
#. Tag: para
#, no-c-format
msgid ""
", <xref linkend=\"ST_SimplifyVW\"/>, <xref linkend=\"ST_CoverageSimplify\"/>"
msgstr ""
+", <xref linkend=\"ST_SimplifyVW\"/>, <xref linkend=\"ST_CoverageSimplify\"/>"
#. Tag: refpurpose
#, no-c-format
Summary of changes:
doc/po/fr/postgis-manual.po | 16 +++++++++++++---
1 file changed, 13 insertions(+), 3 deletions(-)
hooks/post-receive
