[SCM] PostGIS branch master updated. 3.6.0rc2-428-ga5ceec2d8
Wed Apr 1 13:13:35 PDT 2026
the project "PostGIS".
       via  a5ceec2d826c271bab53fc5614dc26c4d174bc9b (commit)
       via  953790c4b42241b7a37f36e846a1896a01a0ca15 (commit)
      from  ae9559672d2e329cee44bd697bac8411b94af13f (commit)
revisions in full, below.
commit a5ceec2d826c271bab53fc5614dc26c4d174bc9b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Apr 1 13:07:12 2026 -0700
    Ensure ST_CoverageEdges tests are deterministic with ORDER BY
diff --git a/regress/core/geos315.sql b/regress/core/geos315.sql
index 4c30bfbfe..b30f0657a 100644
--- a/regress/core/geos315.sql
+++ b/regress/core/geos315.sql
@@ -51,19 +51,19 @@ INSERT INTO coverage_edges VALUES
 (6, 2, 'POLYGON ((10 0, 10 10, 20 10, 20 0, 10 0))');
 SELECT 'coverage edges all' AS test,
-  ST_AsText(ST_CoverageEdges(ST_Collect(geom)))
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom ORDER BY seq)))
 FROM coverage_edges WHERE id = 6;
 SELECT 'coverage edges exterior' AS test,
-  ST_AsText(ST_CoverageEdges(ST_Collect(geom), 1))
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom ORDER BY seq), 1))
 SELECT 'coverage edges interior' AS test,
-  ST_AsText(ST_CoverageEdges(ST_Collect(geom), 2))
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom ORDER BY seq), 2))
 SELECT 'coverage edges array' AS test,
-  ST_AsText(ST_CoverageEdges(array_agg(geom)))
+  ST_AsText(ST_CoverageEdges(array_agg(geom ORDER BY seq)))
 DROP TABLE coverage_edges;
commit 953790c4b42241b7a37f36e846a1896a01a0ca15
Date:   Wed Apr 1 13:01:45 2026 -0700
    Move ST_CoverageEdges and ST_MinimumSpanningTree tests to version-gated geos315 test file
diff --git a/regress/core/coverage.sql b/regress/core/coverage.sql
index 159022e83..9c456410c 100644
--- a/regress/core/coverage.sql
+++ b/regress/core/coverage.sql
@@ -101,29 +101,3 @@ FROM squares
 GROUP BY i, j
 ORDER By i, j;
-CREATE TABLE coverage_edges (id integer, seq integer, geom geometry);
-INSERT INTO coverage_edges VALUES
-(6, 1, 'POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))'),
-(6, 2, 'POLYGON ((10 0, 10 10, 20 10, 20 0, 10 0))');
-SELECT 'coverage edges all' AS test,
-FROM coverage_edges WHERE id = 6;
-SELECT 'coverage edges exterior' AS test,
-SELECT 'coverage edges interior' AS test,
-SELECT 'coverage edges array' AS test,
-DROP TABLE coverage_edges;
diff --git a/regress/core/coverage_expected b/regress/core/coverage_expected
index 2a0304871..2b456107a 100644
--- a/regress/core/coverage_expected
+++ b/regress/core/coverage_expected
@@ -36,7 +36,3 @@ grid squares|1|2|50000
 grid squares|2|0|50000
 grid squares|2|1|50000
 grid squares|2|2|10000
-coverage edges all|MULTILINESTRING((10 10,10 0),(10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
-coverage edges exterior|MULTILINESTRING((10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
-coverage edges interior|MULTILINESTRING((10 10,10 0))
-coverage edges array|MULTILINESTRING((10 10,10 0),(10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
diff --git a/regress/core/spanningtree.sql b/regress/core/geos315.sql
similarity index 66%
rename from regress/core/spanningtree.sql
rename to regress/core/geos315.sql
index 063c18855..4c30bfbfe 100644
--- a/regress/core/spanningtree.sql
@@ -1,4 +1,6 @@
+-- ST_MinimumSpanningTree
 -- Connected graph (all one cluster)
 SELECT 'connected', id, ST_MinimumSpanningTree(geom) OVER (ORDER BY id) FROM (VALUES
     (1, 'LINESTRING(0 0,1 0)'::geometry),
@@ -40,3 +42,28 @@ SELECT 'empty', id, ST_MinimumSpanningTree(geom) OVER (ORDER BY id), ST_AsText(g
     (6, 'LINESTRING(1 0,0 1)'::geometry)
 ) AS t(id, geom);
+-- ST_CoverageEdges
+CREATE TABLE coverage_edges (id integer, seq integer, geom geometry);
+INSERT INTO coverage_edges VALUES
+(6, 1, 'POLYGON ((0 0, 0 10, 10 10, 10 0, 0 0))'),
+(6, 2, 'POLYGON ((10 0, 10 10, 20 10, 20 0, 10 0))');
+SELECT 'coverage edges all' AS test,
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom)))
+FROM coverage_edges WHERE id = 6;
+SELECT 'coverage edges exterior' AS test,
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom), 1))
+SELECT 'coverage edges interior' AS test,
+  ST_AsText(ST_CoverageEdges(ST_Collect(geom), 2))
+SELECT 'coverage edges array' AS test,
+  ST_AsText(ST_CoverageEdges(array_agg(geom)))
+DROP TABLE coverage_edges;
diff --git a/regress/core/spanningtree_expected b/regress/core/geos315_expected
similarity index 60%
rename from regress/core/spanningtree_expected
rename to regress/core/geos315_expected
index 8421fd061..9eae3c024 100644
--- a/regress/core/spanningtree_expected
+++ b/regress/core/geos315_expected
@@ -22,3 +22,7 @@ empty|3|0|LINESTRING EMPTY
 empty|4|1|LINESTRING(1 1,1 0)
 empty|5|0|LINESTRING(0 0,1 1)
 empty|6|1|LINESTRING(1 0,0 1)
+coverage edges all|MULTILINESTRING((10 10,10 0),(10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
+coverage edges exterior|MULTILINESTRING((10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
+coverage edges interior|MULTILINESTRING((10 10,10 0))
+coverage edges array|MULTILINESTRING((10 10,10 0),(10 0,0 0,0 10,10 10),(10 10,20 10,20 0,10 0))
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index d34642e3d..fc998a755 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -168,7 +168,7 @@ endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31500),1)
 	TESTS += \
-		$(top_srcdir)/regress/core/spanningtree
+		$(top_srcdir)/regress/core/geos315
 endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 31200),1)
Summary of changes:
 regress/core/coverage.sql                          | 26 ---------------------
 regress/core/coverage_expected                     |  4 ----
 regress/core/{spanningtree.sql => geos315.sql}     | 27 ++++++++++++++++++++++
 .../{spanningtree_expected => geos315_expected}    |  4 ++++
 regress/core/tests.mk.in                           |  2 +-
 5 files changed, 32 insertions(+), 31 deletions(-)
 rename regress/core/{spanningtree.sql => geos315.sql} (65%)
 rename regress/core/{spanningtree_expected => geos315_expected} (60%)
hooks/post-receive
