[PostGIS] #6066: Pg19 + topology crash on regression test
trac at osgeo.org
Tue Apr 7 15:43:14 PDT 2026
Reporter: pramsey | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.6.2
Component: postgis | Version: master
Resolution: | Keywords:
Comment (by pramsey):
How I am exercising this
# clean database
dropdb postgis_reg
./regress/run_test.pl --nodrop --topology ./regress/core/wkt
psql postgis_reg
Setup the scenario
SELECT NULL FROM topology.CreateTopology('t5118');
CREATE TABLE t5118f (id int);
SELECT NULL FROM topology.AddTopoGeometryColumn('t5118', 'public',
't5118f', 'g', 'LINE');
Hit the red buttton
INSERT INTO t5118f(g) SELECT toTopoGeom('LINESTRING(0 0, 10 0)', 't5118',
1);
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6066#comment:3>
