[PostGIS] #6066: Pg19 + topology crash on regression test
trac at osgeo.org
Wed Apr 8 14:16:17 PDT 2026
Reporter: pramsey | Owner: strk
Type: defect | Status: assigned
Priority: blocker | Milestone: PostGIS 3.6.2
Component: topology | Version: master
Resolution: | Keywords:
Comment (by strk):
I confirm the crash with procedure in comment:3 and noticed that omitting
the INSERT (ie: only calling the toTopoGeom select) does not trigger the
crash.
Dropping all triggers doesn't help instead.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6066#comment:6>
