[PostGIS] #6066: Pg19 + topology crash on regression test
PostGIS trac at osgeo.org
Wed Apr 8 14:23:06 PDT 2026
  Reporter:  pramsey   |      Owner:  strk
      Type:  defect    |     Status:  assigned
  Priority:  blocker   |  Milestone:  PostGIS 3.6.2
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Comment (by strk):
 Another observation. By adding a second TopoGeometry column of type
 puntual:
  1. You can get the crash ALSO when adding/inserting a POINT TopoGeometry
  2. If you try to insert a POINT geometry into the LINEAL column you still
 get the WARNINGs but not the final crash (violation of check constraint
 prevents the crash)
 WARNING:  resource was not closed: relation "face"
 WARNING:  resource was not closed: relation "face_primary_key"
 WARNING:  resource was not closed: TupleDesc 0x7fae0bf25590 (17671,-1)
 WARNING:  resource was not closed: TupleDesc 0x7fae0bf103c8 (17681,-1)
 ERROR:  new row for relation "t5118f" violates check constraint
 "check_topogeom_g"
 I've to say this all sounds to me like a bug in PostgreSQL, not PostGIS.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6066#comment:7>
