[PostGIS] #6026: Distance operator <-> returns "tuple order" error
trac at osgeo.org
Wed Apr 8 14:44:47 PDT 2026
Reporter: dirc | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 3.5.x
Resolution: | Keywords: distance, operator, tuple, order
Comment (by Paul Ramsey <pramsey@…>):
In [changeset:"e880eb8371ee31ada8b11c0fa580b08f1d4dc806/git" e880eb8/git]:
{{{#!CommitTicketReference repository="git"
revision="e880eb8371ee31ada8b11c0fa580b08f1d4dc806"
Clean up and add another special case to lw_dist2d_pt_seg()
When the seg is vertical or horizontal, we construct the
nearest points to avoid getting a difference between the
more-exact distance calculation that does not construct
and the naturally constructive process of building a bbox,
which can result in a situation where the "real distance"
between two objects can be less than the "box distance", which
is simply not allowed.
References #6026
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6026#comment:8>
