[PostGIS] #6026: Distance operator <-> returns "tuple order" error
PostGIS trac at osgeo.org
Wed Apr 8 14:43:09 PDT 2026
  Reporter:  dirc     |      Owner:  pramsey
      Type:  defect   |     Status:  new
  Priority:  medium   |  Milestone:
 Component:  postgis  |    Version:  3.5.x
Resolution:           |   Keywords:  distance, operator, tuple, order
Comment (by Paul Ramsey <pramsey@…>):
 In [changeset:"e91db587b9ec8dcb4cbea6faa48e2b92be100290/git" e91db58/git]:
 {{{#!CommitTicketReference repository="git"
 revision="e91db587b9ec8dcb4cbea6faa48e2b92be100290"
 Clean up and add another special case to lw_dist2d_pt_seg()
 When the seg is vertical or horizontal, we construct the
 nearest points to avoid getting a difference between the
 more-exact distance calculation that does not construct
 and the naturally constructive process of building a bbox,
 which can result in a situation where the "real distance"
 between two objects can be less than the "box distance", which
 is simply not allowed.
 References #6026
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6026#comment:7>
