[SCM] PostGIS branch stable-3.3 updated. 3.3.9-12-gb1e96843c
git at osgeo.org
git at osgeo.org
Wed Apr 8 14:48:01 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via b1e96843c5aebc7effb907fbe9ee3c815447a40f (commit)
from 9abdb5153690679b44cced668ba32c9cba833dc5 (commit)
revisions in full, below.
commit b1e96843c5aebc7effb907fbe9ee3c815447a40f
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Wed Apr 8 14:47:46 2026 -0700
Clean up and add another special case to lw_dist2d_pt_seg()
When the seg is vertical or horizontal, we construct the
nearest points to avoid getting a difference between the
more-exact distance calculation that does not construct
and the naturally constructive process of building a bbox,
which can result in a situation where the "real distance"
between two objects can be less than the "box distance", which
is simply not allowed.
References #6026
diff --git a/NEWS b/NEWS
index afccd4faf..cb3aec833 100644
--- a/NEWS
+++ b/NEWS
@@ -10,6 +10,7 @@ PostGIS 3.3.10
and Daniel Bakker
- GH-850 Use quote_identifier to build tables in pgis_tablefromflatgeobuf (Ariel Mashraki)
- #6060, fully quality calls to helper functions (Paul Ramsey)
+ - #6026, KNN failure in rare IEEE double rounding case (Paul Ramsey)
PostGIS 3.3.9
diff --git a/liblwgeom/measures.c b/liblwgeom/measures.c
index 2fd217e90..2774b38c0 100644
--- a/liblwgeom/measures.c
+++ b/liblwgeom/measures.c
@@ -2216,106 +2216,161 @@ End of New faster distance calculations
Functions in common for Brute force and new calculation
-lw_dist2d_comp from p to line A->B
-This one is now sending every occasion to lw_dist2d_pt_pt
-Before it was handling occasions where r was between 0 and 1 internally
-and just returning the distance without identifying the points.
-To get this points it was necessary to change and it also showed to be about 10%faster.
int
-lw_dist2d_pt_seg(const POINT2D *p, const POINT2D *A, const POINT2D *B, DISTPTS *dl)
+lw_dist2d_pt_seg(const POINT2D *C, const POINT2D *A, const POINT2D *B, DISTPTS *dl)
- double r;
- LWDEBUG(2, "lw_dist2d_pt_seg called");
- /*if start==end, then use pt distance */
- if ((A->x == B->x) && (A->y == B->y))
- LWDEBUG(2, "lw_dist2d_pt_seg found first and last segment points being the same");
- return lw_dist2d_pt_pt(p, A, dl);
+ POINT2D P;
+ int is_vertical = (A->x == B->x);
+ int is_horizontal = (A->y == B->y);
- * otherwise, we use comp.graphics.algorithms
- * Frequently Asked Questions method
+ * If A == B, then use pt-pt distance
+ if (is_vertical && is_horizontal)
+ return lw_dist2d_pt_pt(C, A, dl);
+ * We use comp.graphics.algorithms Frequently Asked Questions method
+ * Let the point be C (Cx,Cy) and the line be AB (Ax,Ay) to (Bx,By).
+ * Let P be the point of perpendicular projection of C on AB. The parameter
+ * r, which indicates P's position along AB, is computed by the dot product
+ * of AC and AB divided by the square of the length of AB:
+ * (1) AC dot AB
+ * r = ---------
+ * ||AB||^2
+ * The length of a line segment
+ * L = sqrt( (Bx-Ax)^2 + (By-Ay)^2 )
+ * So (1) expands to:
+ * (Cx-Ax)(Bx-Ax) + (Cy-Ay)(By-Ay)
+ * r = -------------------------------
+ * L^2
+ * r has the following meaning:
+ * r=0 P = A
+ * r=1 P = B
+ * r<0 P is on the backward extension of AB
+ * r>1 P is on the forward extension of AB
+ * 0<r<1 P is interior to AB
- * (1) AC dot AB
- * r = ---------
- * ||AB||^2
- * r has the following meaning:
- * r=0 P = A
- * r=1 P = B
- * r<0 P is on the backward extension of AB
- * r>1 P is on the forward extension of AB
- * 0<r<1 P is interior to AB
- r = ((p->x - A->x) * (B->x - A->x) + (p->y - A->y) * (B->y - A->y)) /
- ((B->x - A->x) * (B->x - A->x) + (B->y - A->y) * (B->y - A->y));
+ double dx = B->x - A->x;
+ double dy = B->y - A->y;
+ double L2 = (dx*dx) + (dy*dy);
- LWDEBUGF(2, "lw_dist2d_pt_seg found r = %.15g", r);
+ double r = ((C->x - A->x) * dx + (C->y - A->y) * dy) / L2;
- /*This is for finding the maxdistance.
- the maxdistance have to be between two vertexes, compared to mindistance which can be between two vertexes.*/
+ * This is for finding the maxdistance.
+ * The maxdistance have to be between two vertices,
+ * compared to mindistance which can be between two vertices.
if (dl->mode == DIST_MAX)
if (r >= 0.5)
else /* (r < 0.5) */
- return lw_dist2d_pt_pt(p, B, dl);
+ return lw_dist2d_pt_pt(C, B, dl);
- if (r < 0) /*If p projected on the line is outside point A*/
- if (r >= 1) /*If p projected on the line is outside point B or on point B*/
- /*If the point p is on the segment this is a more robust way to find out that*/
- if ((((A->y - p->y) * (B->x - A->x) == (A->x - p->x) * (B->y - A->y))) && (dl->mode == DIST_MIN))
- lw_dist2d_distpts_set(dl, 0, p, p);
- (2)
- (Ay-Cy)(Bx-Ax)-(Ax-Cx)(By-Ay)
- s = -----------------------------
- L^2
+ * If projected point P is outside point A
+ if (r < 0)
- Then the distance from C to P = |s|*L.
+ * If projected point P is is outside
+ * point B or on point B
+ if (r >= 1)
- double s = ((A->y - p->y) * (B->x - A->x) - (A->x - p->x) * (B->y - A->y)) /
+ * If point C is on the segment AB then
+ * distance is zero and nearest point is C
+ if ((A->y - C->y) * dx == (A->x - C->x) * dy)
+ lw_dist2d_distpts_set(dl, 0.0, C, C);
- double dist = fabs(s) * sqrt(((B->x - A->x) * (B->x - A->x) + (B->y - A->y) * (B->y - A->y)));
- if ( dist < dl->distance )
+ * The point P can then be found:
+ * Px = Ax + r(Bx-Ax)
+ * Py = Ay + r(By-Ay)
+ * And the distance from A to P = r*L.
+ * If the projection of point C on the segment is
+ * between A and B then we find that "point on segment"
+ * and send it to lw_dist2d_pt_pt
+ if (is_horizontal || is_vertical)
+ P.x = A->x + r * dx;
+ P.y = A->y + r * dy;
+ return lw_dist2d_pt_pt(C, &P, dl);
+ * Use another parameter s to indicate the location along PC, with the
+ * following meaning:
+ * s<0 C is left of AB
+ * s>0 C is right of AB
+ * s=0 C is on AB
+ * Compute s as follows:
+ * (Ay-Cy)(Bx-Ax)-(Ax-Cx)(By-Ay)
+ * s = -----------------------------
+ * L^2
+ * Then the distance from C to P = s*L.
+ * Calculate distance without reference to the
+ * projected point P.
+ double s = ((A->y - C->y) * dx - (A->x - C->x) * dy) / L2;
+ double dist = fabs(s) * sqrt(L2);
+ // double dist = fabs(s) * hypot(dx, dy);
+ if (dist < dl->distance)
dl->distance = dist;
- POINT2D c;
- c.x = A->x + r * (B->x - A->x);
- c.y = A->y + r * (B->y - A->y);
if (dl->twisted > 0)
- dl->p1 = *p;
- dl->p2 = c;
+ dl->p1 = *C;
+ dl->p2 = P;
else
- dl->p1 = c;
- dl->p2 = *p;
+ dl->p1 = P;
+ dl->p2 = *C;
return LW_TRUE;
/** Compares incoming points and stores the points closest to each other or most far away from each other depending on
* dl->mode (max or min) */
int
Summary of changes:
NEWS | 1 +
liblwgeom/measures.c | 177 +++++++++++++++++++++++++++++++++------------------
2 files changed, 117 insertions(+), 61 deletions(-)
hooks/post-receive
