[PostGIS] #6061: segmentation fault when loading geometries
trac at osgeo.org
Thu Apr 9 09:03:49 PDT 2026
Reporter: maxsynytsky1v | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.2
Component: postgis | Version: 3.6.x
Resolution: | Keywords:
Comment (by maxsynytsky1v):
Thanks a lot for the support, I will try to look into the trimming issue.
So far, I can see that SDE.ST_ASTEXT does not truncate this geometry, so
most likely this happens in ora2pg.
Do you need any other help from me?
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6061#comment:17>
