[SCM] PostGIS branch master updated. 3.6.0rc2-440-g6adcabe8e
Mon Apr 13 00:36:03 PDT 2026
the project "PostGIS".
       via  6adcabe8e99b2c5a67b45cfe4758cc08ee332376 (commit)
      from  6f3355d3a1046c5f1af80e499cbad6f4f438dd9d (commit)
revisions in full, below.
commit 6adcabe8e99b2c5a67b45cfe4758cc08ee332376
Author: Sandro Santilli <strk at kbt.io>
Date:   Mon Apr 13 09:35:46 2026 +0200
    Move SFGAL orientation test in its own file
diff --git a/sfcgal/regress/orientation.sql b/sfcgal/regress/orientation.sql
new file mode 100644
index 000000000..b9b4857d7
--- /dev/null
+++ b/sfcgal/regress/orientation.sql
@@ -0,0 +1,4 @@
+SELECT 'CG_Orientation_1', CG_Orientation(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'CG_Orientation_2', CG_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
diff --git a/sfcgal/regress/orientation_expected b/sfcgal/regress/orientation_expected
index 000000000..58b10f126
--- /dev/null
+++ b/sfcgal/regress/orientation_expected
@@ -0,0 +1,4 @@
+CG_Orientation_1|-1
+CG_Orientation_2|1
+CG_Orientation_2|1
diff --git a/sfcgal/regress/regress_sfcgal.sql b/sfcgal/regress/regress_sfcgal.sql
index 881c19439..5d35443c2 100644
--- a/sfcgal/regress/regress_sfcgal.sql
+++ b/sfcgal/regress/regress_sfcgal.sql
@@ -26,8 +26,6 @@ ELSE
 END;
 SELECT 'CG_ForceLHR', ST_AsText(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'CG_Orientation_1', CG_Orientation(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'CG_Orientation_2', CG_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
 SELECT 'CG_MinkowskiSum', ST_AsText(CG_MinkowskiSum('LINESTRING(0 0,4 0)','POLYGON((0 0,1 0,1 1,0 1,0 0))'));
 SELECT 'CG_ConstrainedDelaunayTriangles', ST_AsText(CG_ConstrainedDelaunayTriangles('GEOMETRYCOLLECTION(POINT(0 0), POLYGON((2 2, 2 -2, 4 0, 2 2)))'));
 SELECT 'CG_3DConvexHull', CG_3DArea(CG_3DConvexHull('MULTIPOINTZ(0 0 5, 1 5 3, 5 7 6, 9 5 3 , 5 7 5, 6 3 5)'))::numeric(10,4);
@@ -62,8 +60,6 @@ ELSE
 END;
diff --git a/sfcgal/regress/regress_sfcgal_expected b/sfcgal/regress/regress_sfcgal_expected
index bdbc702da..261cb63d3 100644
--- a/sfcgal/regress/regress_sfcgal_expected
+++ b/sfcgal/regress/regress_sfcgal_expected
@@ -6,8 +6,6 @@ CG_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
 CG_Extrude_line|POLYHEDRALSURFACE Z (((0 0 0,1 0 0,1 1 0,0 1 0,0 0 0)))
 CG_Extrude_surface|POLYHEDRALSURFACE Z (((1 1 0,1 0 0,0 1 0,1 1 0)),((0 1 1,1 0 1,1 1 1,0 1 1)),((1 0 0,0 0 0,0 1 0,1 0 0)),((0 1 1,0 0 1,1 0 1,0 1 1)),((1 0 0,1 1 0,1 1 1,1 0 1,1 0 0)),((1 1 0,0 1 0,0 1 1,1 1 1,1 1 0)),((0 1 0,0 0 0,0 0 1,0 1 1,0 1 0)),((0 0 0,1 0 0,1 0 1,0 0 1,0 0 0)))
 CG_ForceLHR|POLYGON((0 0,1 0,1 1,0 1,0 0))
-CG_Orientation_1|-1
-CG_Orientation_2|1
 CG_MinkowskiSum|MULTIPOLYGON(((0 0,1 0,5 0,5 1,4 1,0 1,0 0)))
 CG_ConstrainedDelaunayTriangles|TIN(((4 0,2 2,2 -2,4 0)),((2 2,0 0,2 -2,2 2)))
 CG_3DConvexHull|80.9227
@@ -19,8 +17,6 @@ CG_Extrude_point|LINESTRING Z (0 0 0,1 0 0)
-CG_Orientation_2|1
diff --git a/sfcgal/regress/tests.mk.in b/sfcgal/regress/tests.mk.in
index 557edcd2f..8dd78b2ec 100644
--- a/sfcgal/regress/tests.mk.in
+++ b/sfcgal/regress/tests.mk.in
@@ -15,7 +15,8 @@ POSTGIS_SFCGAL_VERSION=@POSTGIS_SFCGAL_VERSION@
 TESTS += \
 		$(top_srcdir)/sfcgal/regress/regress_sfcgal \
-		$(top_srcdir)/sfcgal/regress/approximatemedialaxis.sql
+		$(top_srcdir)/sfcgal/regress/approximatemedialaxis.sql \
+		$(top_srcdir)/sfcgal/regress/orientation.sql
 ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 10401),1)
 	TESTS += \
Summary of changes:
 sfcgal/regress/orientation.sql         | 4 ++++
 sfcgal/regress/orientation_expected    | 4 ++++
 sfcgal/regress/regress_sfcgal.sql      | 4 ----
 sfcgal/regress/regress_sfcgal_expected | 4 ----
 sfcgal/regress/tests.mk.in             | 3 ++-
 5 files changed, 10 insertions(+), 9 deletions(-)
 create mode 100644 sfcgal/regress/orientation.sql
 create mode 100644 sfcgal/regress/orientation_expected
hooks/post-receive
