[SCM] PostGIS branch master updated. 3.6.0rc2-442-gdca869b30
git at osgeo.org
git at osgeo.org
Mon Apr 13 06:50:16 PDT 2026
the project "PostGIS".
via dca869b309a2d7fda9fd1c173a326540af9f34d8 (commit)
from af86ae40655391f797ad95cf97b6e7fca5cb7e33 (commit)
revisions in full, below.
commit dca869b309a2d7fda9fd1c173a326540af9f34d8
Author: Sandro Santilli <strk at kbt.io>
Date: Mon Apr 13 15:48:22 2026 +0200
Add SFCGAL test for ring orientation case requiring higher precision
References #6065
diff --git a/sfcgal/regress/orientation.sql b/sfcgal/regress/orientation.sql
index f30ed17b7..a237b636c 100644
--- a/sfcgal/regress/orientation.sql
+++ b/sfcgal/regress/orientation.sql
@@ -1,2 +1,4 @@
-SELECT 'CG_Orientation_1', CG_Orientation(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
-SELECT 'CG_Orientation_2', CG_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))'));
+SELECT 'CG_Orientation_1', CG_Orientation(CG_ForceLHR('POLYGON((0 0,0 1,1 1,1 0,0 0))')); -- Left hand rule: counterclockwise (interior is on the left side)
+SELECT 'CG_Orientation_2', CG_Orientation(ST_ForceRHR('POLYGON((0 0,0 1,1 1,1 0,0 0))')); -- Right hand rule: clockwise (interior is on the right side)
+SELECT 'CG_Orientation_3', CG_Orientation('POLYGON((0 0,0 1,1 1,1 0,0 0))'); -- clockwise
+SELECT 't6065', CG_Orientation('0103000000010000000A000000890205230D6C31408177583619475140FD613B270D6C314031AA5436194751405D58985776943140195EE965DE47514085FFA6647B9F31408FC1C62B394851405D58985776943140195EE965DE475140FD613B270D6C314031AA543619475140A4613B270D6C31402FAA543619475140890205230D6C31408177583619475140320205230D6C31407E77583619475140890205230D6C31408177583619475140');
diff --git a/sfcgal/regress/orientation_expected b/sfcgal/regress/orientation_expected
index 6479c3034..a6d7c7cc3 100644
--- a/sfcgal/regress/orientation_expected
+++ b/sfcgal/regress/orientation_expected
@@ -1,2 +1,4 @@
CG_Orientation_1|-1
CG_Orientation_2|1
+CG_Orientation_3|1
+t6065|1
Summary of changes:
sfcgal/regress/orientation.sql | 6 ++++--
sfcgal/regress/orientation_expected | 2 ++
2 files changed, 6 insertions(+), 2 deletions(-)
hooks/post-receive
