[SCM] PostGIS branch master updated. 3.6.0rc2-450-gd4f15e43a
Mon Apr 13 11:44:00 PDT 2026
the project "PostGIS".
       via  d4f15e43ae5602910bd05e65685022d485063e73 (commit)
       via  9f1c511313354c07cb935830c727119a9ff62204 (commit)
       via  23c502b0b5799833d644341036ada1ee01e83654 (commit)
       via  f3d2c94a735c3b8bad66b12c22b65cda09c737f9 (commit)
       via  5df3844230e224aca1aa46cdf0ef34334ad4f9a4 (commit)
       via  910963ad286a9fe07bb926d6832f33f40d29e741 (commit)
       via  0fce8d9bd0ef93eb9965991d41e4b9d1a5fc3629 (commit)
       via  a3641359a7663c48b46957b79632706777c30b86 (commit)
      from  dca869b309a2d7fda9fd1c173a326540af9f34d8 (commit)
revisions in full, below.
commit d4f15e43ae5602910bd05e65685022d485063e73
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Apr 10 16:33:36 2026 -0700
    Remove potential null dereference in ptarray_calc_areas()
diff --git a/liblwgeom/effectivearea.c b/liblwgeom/effectivearea.c
index 6efeb0eb5..a16dfce1c 100644
--- a/liblwgeom/effectivearea.c
+++ b/liblwgeom/effectivearea.c
@@ -358,6 +358,9 @@ void ptarray_calc_areas(EFFECTIVE_AREAS *ea, int avoid_collaps, int set_area, do
 	const double *P2;
 	const double *P3;
+	if (npoints < 2)
+		lwerror("%s: not enough points provided", __func__);
 	P1 = (double*)getPoint_internal(ea->inpts, 0);
 	P2 = (double*)getPoint_internal(ea->inpts, 1);
commit 9f1c511313354c07cb935830c727119a9ff62204
Date:   Fri Apr 10 16:33:16 2026 -0700
    Remove potential null dereference in lwcircstring_linearize()
diff --git a/liblwgeom/lwstroke.c b/liblwgeom/lwstroke.c
index 3adfeb055..5bea73a24 100644
--- a/liblwgeom/lwstroke.c
+++ b/liblwgeom/lwstroke.c
@@ -565,8 +565,11 @@ lwcircstring_linearize(const LWCIRCSTRING *icurve, double tol,
 			return NULL;
-	getPoint4d_p(icurve->points, icurve->points->npoints-1, &p1);
-	ptarray_append_point(ptarray, &p1, LW_FALSE);
+	if (icurve->points->npoints > 0)
+		getPoint4d_p(icurve->points, icurve->points->npoints-1, &p1);
+		ptarray_append_point(ptarray, &p1, LW_FALSE);
 	oline = lwline_construct(icurve->srid, NULL, ptarray);
 	return oline;
commit 23c502b0b5799833d644341036ada1ee01e83654
Date:   Fri Apr 10 15:55:18 2026 -0700
    Remove potential null dereference in pt_in_ring_3d()
diff --git a/liblwgeom/measures3d.c b/liblwgeom/measures3d.c
index 57b29ffe2..bc3e6d063 100644
--- a/liblwgeom/measures3d.c
+++ b/liblwgeom/measures3d.c
@@ -1579,6 +1579,9 @@ pt_in_ring_3d(const POINT3DZ *p, const POINTARRAY *ring, PLANE3D *plane)
 	POINT3DZ first, last;
+	if ( !ring || ring->npoints == 0 )
+		lwerror("%s called on empty pointarray", __func__);
 	getPoint3dz_p(ring, 0, &first);
 	getPoint3dz_p(ring, ring->npoints - 1, &last);
 	if (memcmp(&first, &last, sizeof(POINT3DZ)))
commit f3d2c94a735c3b8bad66b12c22b65cda09c737f9
Date:   Fri Apr 10 15:36:05 2026 -0700
    Remove potential null dereference from ptarray_contains_point_partial()
diff --git a/liblwgeom/ptarray.c b/liblwgeom/ptarray.c
index df5782adb..65b72290b 100644
--- a/liblwgeom/ptarray.c
+++ b/liblwgeom/ptarray.c
@@ -971,10 +971,13 @@ ptarray_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int chec
 	const POINT2D *seg1, *seg2;
 	double ymin, ymax;
+	if ( !pa || !pa->npoints )
 	seg1 = getPoint2d_cp(pa, 0);
 	seg2 = getPoint2d_cp(pa, pa->npoints-1);
 	if ( check_closed && ! p2d_same(seg1, seg2) )
-		lwerror("ptarray_contains_point called on unclosed ring");
+		lwerror("%s called on unclosed ring", __func__);
 	for ( i=1; i < pa->npoints; i++ )
commit 5df3844230e224aca1aa46cdf0ef34334ad4f9a4
Date:   Fri Apr 10 15:31:16 2026 -0700
    Remove unused function pt_in_ring_2d()
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index b9081db9c..9ff00e1a4 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -1365,7 +1365,6 @@ extern uint32_t lwcompound_num_curves(const LWCOMPOUND *compound);
 extern const LWGEOM *lwcollection_getsubcurve(const LWCOMPOUND *compound, uint32_t gnum);
 extern double ptarray_length_2d(const POINTARRAY *pts);
-extern int pt_in_ring_2d(const POINT2D *p, const POINTARRAY *ring);
 extern int azimuth_pt_pt(const POINT2D *p1, const POINT2D *p2, double *ret);
 extern LWPOINT* lwpoint_project_lwpoint(const LWPOINT* lwpoint1, const LWPOINT* lwpoint2, double distance);
 extern LWPOINT* lwpoint_project(const LWPOINT* lwpoint1, double distance, double azimuth);
diff --git a/liblwgeom/liblwgeom_internal.h b/liblwgeom/liblwgeom_internal.h
index 828c81eeb..a8b28b503 100644
--- a/liblwgeom/liblwgeom_internal.h
+++ b/liblwgeom/liblwgeom_internal.h
@@ -471,7 +471,6 @@ int lw_arc_is_pt(const POINT2D *A1, const POINT2D *A2, const POINT2D *A3);
 int lw_pt_on_segment(const POINT2D* p1, const POINT2D* p2, const POINT2D* p);
 double lw_seg_length(const POINT2D *A1, const POINT2D *A2);
 double lw_arc_length(const POINT2D *A1, const POINT2D *A2, const POINT2D *A3);
-int pt_in_ring_2d(const POINT2D *p, const POINTARRAY *ring);
 int ptarray_contains_point(const POINTARRAY *pa, const POINT2D *pt);
 int ptarrayarc_contains_point(const POINTARRAY *pa, const POINT2D *pt);
 int ptarray_contains_point_partial(const POINTARRAY *pa, const POINT2D *pt, int check_closed, int *winding_number);
diff --git a/liblwgeom/lwalgorithm.c b/liblwgeom/lwalgorithm.c
index 2ddc721da..75d8b3549 100644
--- a/liblwgeom/lwalgorithm.c
+++ b/liblwgeom/lwalgorithm.c
@@ -293,62 +293,6 @@ lw_arc_center(const POINT2D *p1, const POINT2D *p2, const POINT2D *p3, POINT2D *
 	return cr;
-int
-pt_in_ring_2d(const POINT2D *p, const POINTARRAY *ring)
-	int cn = 0;    /* the crossing number counter */
-	uint32_t i;
-	const POINT2D *v1, *v2;
-	const POINT2D *first, *last;
-	first = getPoint2d_cp(ring, 0);
-	last = getPoint2d_cp(ring, ring->npoints-1);
-	if ( memcmp(first, last, sizeof(POINT2D)) )
-		lwerror("pt_in_ring_2d: V[n] != V[0] (%g %g != %g %g)",
-		        first->x, first->y, last->x, last->y);
-		return LW_FALSE;
-	LWDEBUGF(2, "pt_in_ring_2d called with point: %g %g", p->x, p->y);
-	/* printPA(ring); */
-	/* loop through all edges of the polygon */
-	v1 = getPoint2d_cp(ring, 0);
-	for (i=0; i<ring->npoints-1; i++)
-		double vt;
-		v2 = getPoint2d_cp(ring, i+1);
-		/* edge from vertex i to vertex i+1 */
-		if
-		    /* an upward crossing */
-		    ((v1->y <= p->y) && (v2->y > p->y))
-		    /* a downward crossing */
-		    || ((v1->y > p->y) && (v2->y <= p->y))
-			vt = (double)(p->y - v1->y) / (v2->y - v1->y);
-			/* P->x <intersect */
-			if (p->x < v1->x + vt * (v2->x - v1->x))
-				/* a valid crossing of y=p->y right of p->x */
-				++cn;
-		v1 = v2;
-	LWDEBUGF(3, "pt_in_ring_2d returning %d", cn&1);
-	return (cn&1);    /* 0 if even (out), and 1 if odd (in) */
 static int
 lw_seg_interact(const POINT2D *p1, const POINT2D *p2, const POINT2D *q1, const POINT2D *q2)
commit 910963ad286a9fe07bb926d6832f33f40d29e741
Date:   Fri Apr 10 15:29:19 2026 -0700
    Remove reported crash in lwcompound_add_lwgeom()
diff --git a/liblwgeom/lwcompound.c b/liblwgeom/lwcompound.c
index 770acdc6b..f33b0f729 100644
--- a/liblwgeom/lwcompound.c
+++ b/liblwgeom/lwcompound.c
@@ -168,6 +168,9 @@ int lwcompound_add_lwgeom(LWCOMPOUND *comp, LWGEOM *geom)
 		/* Last point of the previous component */
 		LWLINE *prevline = (LWLINE*)(col->geoms[col->ngeoms-1]);
+		if (lwline_is_empty(prevline))
+			return LW_FAILURE;
 		getPoint4d_p(newline->points, 0, &first);
 		getPoint4d_p(prevline->points, prevline->points->npoints-1, &last);
commit 0fce8d9bd0ef93eb9965991d41e4b9d1a5fc3629
Date:   Fri Apr 10 13:56:41 2026 -0700
    Remove reported crash in lwline_set_effective_area()
index f0f67c2ea..6efeb0eb5 100644
@@ -464,7 +464,8 @@ static LWLINE* lwline_set_effective_area(const LWLINE *iline,int set_area, doubl
 	LWLINE *oline = lwline_construct_empty(iline->srid, FLAGS_GET_Z(iline->flags), set_m);
+	if (iline->points->npoints < 2)
+		return oline;
 	oline = lwline_construct(iline->srid, NULL, ptarray_set_effective_area(iline->points,2,set_area,trshld));
@@ -491,7 +492,12 @@ static LWPOLY* lwpoly_set_effective_area(const LWPOLY *ipoly,int set_area, doubl
 	for (i = 0; i < ipoly->nrings; i++)
-		POINTARRAY *pa = ptarray_set_effective_area(ipoly->rings[i],avoid_collapse,set_area,trshld);
+		POINTARRAY *pa;
+		if (ipoly->rings[i]->npoints < 4)
+			continue;
+		pa = ptarray_set_effective_area(ipoly->rings[i],avoid_collapse,set_area,trshld);
 		/* Add ring to simplified polygon */
 		if(pa->npoints>=4)
commit a3641359a7663c48b46957b79632706777c30b86
Date:   Fri Apr 10 14:56:21 2026 -0700
    Remove reported crash in lwcompound_is_closed()
index 1e0d5c2ee..770acdc6b 100644
@@ -47,31 +47,40 @@ lwcollection_getsubcurve(const LWCOMPOUND *compound, uint32_t curvenum)
 int
 lwcompound_is_closed(const LWCOMPOUND *compound)
+	const LWLINE *line_start, *line_end;
+	const POINTARRAY *pa_start, *pa_end;
 	int hasz = lwgeom_has_z(lwcompound_as_lwgeom(compound));
 	if (lwgeom_is_empty(lwcompound_as_lwgeom(compound)))
 		return LW_FALSE;
-	for (uint32_t i = 0; i < compound->ngeoms; i++)
+	/* Single entry, closes on itself */
+	if (compound->ngeoms == 1 && lwline_is_closed((LWLINE *)(compound->geoms[0])))
+			return LW_TRUE;
+	/* If internal connectivity is lacking, so is closure */
+	if (!lwcompound_is_valid(compound))
+		return LW_FALSE;
+	/* Internal connection is good, what about start/end points? */
+	line_start = (LWLINE *)(compound->geoms[0]);
+	line_end = (LWLINE *)(compound->geoms[compound->ngeoms-1]);
+	pa_start = line_start->points;
+	pa_end = line_end->points;
+	if (hasz)
-		uint32_t i_end = i == 0 ? compound->ngeoms - 1 : i - 1;
-		const LWLINE *geom_start = (LWLINE *)(compound->geoms[i]);
-		const LWLINE *geom_end = (LWLINE *)(compound->geoms[i_end]);
-		const POINTARRAY *pa_start = geom_start->points;
-		const POINTARRAY *pa_end = geom_end->points;
-		if (hasz)
-			const POINT3D *pt_start = getPoint3d_cp(pa_start, 0);
-			const POINT3D *pt_end = getPoint3d_cp(pa_end, pa_end->npoints-1);
-			if (!p3d_same(pt_start, pt_end))
-				return LW_FALSE;
-		else
-			const POINT2D *pt_start = getPoint2d_cp(pa_start, 0);
-			const POINT2D *pt_end = getPoint2d_cp(pa_end, pa_end->npoints-1);
-			if (!p2d_same(pt_start, pt_end))
-				return LW_FALSE;
+		const POINT3D *pt_start = getPoint3d_cp(pa_start, 0);
+		const POINT3D *pt_end = getPoint3d_cp(pa_end, pa_end->npoints-1);
+		if (!p3d_same(pt_start, pt_end))
+			return LW_FALSE;
+	else
+		const POINT2D *pt_start = getPoint2d_cp(pa_start, 0);
+		const POINT2D *pt_end = getPoint2d_cp(pa_end, pa_end->npoints-1);
+		if (!p2d_same(pt_start, pt_end))
+			return LW_FALSE;
 	return LW_TRUE;
@@ -84,12 +93,24 @@ lwcompound_is_valid(const LWCOMPOUND *compound)
 		return LW_TRUE;
+	/* Only one component, do not need to test connectivity */
+	if (compound->ngeoms == 1)
+		return LW_TRUE;
+	/* Check internal connectivity between components */
 	for (uint32_t i = 1; i < compound->ngeoms; i++)
-		const LWLINE *geom_end = (LWLINE *)(compound->geoms[i-1]);
+		const LWLINE *line_start = (LWLINE *)(compound->geoms[i]);
+		const LWLINE *line_end = (LWLINE *)(compound->geoms[i-1]);
+		/* Empty cannot be a compound component, because it joins nothing */
+		if (lwline_is_empty(line_start) || (lwline_is_empty(line_end)))
+			return LW_FALSE;
 		if (hasz)
Summary of changes:
 liblwgeom/effectivearea.c      | 13 ++++++--
 liblwgeom/liblwgeom.h.in       |  1 -
 liblwgeom/liblwgeom_internal.h |  1 -
 liblwgeom/lwalgorithm.c        | 56 --------------------------------
 liblwgeom/lwcompound.c         | 72 ++++++++++++++++++++++++++++--------------
 liblwgeom/lwstroke.c           |  7 ++--
 liblwgeom/measures3d.c         |  3 ++
 liblwgeom/ptarray.c            |  5 ++-
 8 files changed, 71 insertions(+), 87 deletions(-)
hooks/post-receive
