[SCM] PostGIS branch master updated. 3.6.0rc2-451-g67999e2b1
git at osgeo.org
git at osgeo.org
Mon Apr 13 11:48:39 PDT 2026
the project "PostGIS".
via 67999e2b1d2683ea14785e00e77070a2ced9aa7d (commit)
from d4f15e43ae5602910bd05e65685022d485063e73 (commit)
revisions in full, below.
commit 67999e2b1d2683ea14785e00e77070a2ced9aa7d
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Mon Apr 13 11:48:35 2026 -0700
Add regression tests for Curve handling cases with oddball inputs
diff --git a/regress/core/curvetoline.sql b/regress/core/curvetoline.sql
index 3fe30a78a..ac7e11792 100644
--- a/regress/core/curvetoline.sql
+++ b/regress/core/curvetoline.sql
@@ -60,3 +60,4 @@ SELECT 'multiarc1.maxerr20.sym', ST_AsText(ST_SnapToGrid(ST_CurveToLine(
1 -- Symmetric
), 2));
+SELECT 'ST_CurveToLine EMPTY', ST_CurveToLine('CIRCULARSTRING EMPTY');
diff --git a/regress/core/curvetoline_expected b/regress/core/curvetoline_expected
index 115897e9b..937e6d492 100644
--- a/regress/core/curvetoline_expected
+++ b/regress/core/curvetoline_expected
@@ -6,3 +6,4 @@ semicircle3.sym|LINESTRING(0 0,20 -58,70 -96,130 -96,180 -58,200 0)
semicircle3.sym.ret|LINESTRING(0 0,2 -18,36 -76,100 -100,164 -76,198 -18,200 0)
multiarc1|LINESTRING(0 0,30 -70,100 -100,170 -70,200 0,258 142,400 200,542 142,600 0)
multiarc1.maxerr20.sym|LINESTRING(0 0,50 -86,150 -86,200 0,258 142,400 200,542 142,600 0)
+ST_CurveToLine EMPTY|010200000000000000
diff --git a/regress/core/sql-mm-compoundcurve.sql b/regress/core/sql-mm-compoundcurve.sql
index 2c18afab0..b05b9fcb4 100644
--- a/regress/core/sql-mm-compoundcurve.sql
+++ b/regress/core/sql-mm-compoundcurve.sql
@@ -263,3 +263,7 @@ SELECT 'curve accessors 01',
ST_GeometryType(ST_CurveN(geom,0)) as curven_0,
ST_CurveN(ST_CurveN(geom,3), 1) as curven_3_curven_1
FROM f;
+SELECT 'ST_IsClosed',
+ ST_IsClosed('01090000000200000001020000000200000000000000000000000000000000000000000000000000f03f000000000000f03f010200000000000000'::geometry);
diff --git a/regress/core/sql-mm-compoundcurve_expected b/regress/core/sql-mm-compoundcurve_expected
index 783f64650..eead7ab85 100644
--- a/regress/core/sql-mm-compoundcurve_expected
+++ b/regress/core/sql-mm-compoundcurve_expected
@@ -82,3 +82,4 @@ ERROR: geometry requires more points
curve accessors 01|1|ST_CompoundCurve|ST_LineString||3|ST_LineString|ST_CircularString|ST_LineString|||
+ST_IsClosed|f
Summary of changes:
regress/core/curvetoline.sql | 1 +
regress/core/curvetoline_expected | 1 +
regress/core/sql-mm-compoundcurve.sql | 4 ++++
regress/core/sql-mm-compoundcurve_expected | 1 +
4 files changed, 7 insertions(+)
hooks/post-receive
