[PostGIS] #6065: ValidateTopology fails to report invalid side-labeling
PostGIS trac at osgeo.org
Tue Apr 14 00:35:15 PDT 2026
  Reporter:  strk      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 3.7.0
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Changes (by strk):
 * resolution:   => fixed
 * status:  reopened => closed
Comment:
 MacOS fix for this issue confirmed by CI here:
 https://cirrus-ci.com/task/5319076668506112?logs=test#L1979
 > topology/test/regress/validatetopology .. ok in 256 ms
 Will only close this after the `long double` commit is reverted, to
 double-check.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6065#comment:14>
