[PostGIS] #6067: MacOS CI and winnie failing on topology topogeo_addlinestring, validatetopology
PostGIS trac at osgeo.org
Wed Apr 15 00:36:59 PDT 2026
validatetopology
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  medium    |  Milestone:  PostGIS 3.7.0
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"00440ad2900ced28817d18e4908a13bff455588a/git" 00440ad/git]:
 {{{#!CommitTicketReference repository="git"
 revision="00440ad2900ced28817d18e4908a13bff455588a"
 Skip dangling edges while computing ring orientation in liblwgeom-topo
 Improves CCW determination robustness, passing tests on all CI platforms
 Closes #6067, #6064
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6067#comment:12>
