[PostGIS] #6067: MacOS CI and winnie failing on topology topogeo_addlinestring, validatetopology
PostGIS trac at osgeo.org
Wed Apr 15 08:53:38 PDT 2026
validatetopology
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  reopened
  Priority:  medium    |  Milestone:  PostGIS 3.7.0
 Component:  topology  |    Version:  master
Resolution:            |   Keywords:
Changes (by strk):
 * resolution:  fixed =>
 * status:  closed => reopened
Comment:
 Reopening as the CCW determination based on skipping dangling edges was
 bogus, and the "long double" (now back in effect as of
 [e21fe0083bd1fdd7477e60162b793870f8b536fc/git]) is still not enough to fix
 this case on MacOS
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6067#comment:13>
