[SCM] PostGIS branch master updated. 3.6.0rc2-470-g0feee1927
Fri Apr 17 00:54:49 PDT 2026
the project "PostGIS".
       via  0feee19278e423922717b788dd14cc9823cadc0e (commit)
      from  bb1a71e15fdece2cab099682be270683b529cbc9 (commit)
revisions in full, below.
commit 0feee19278e423922717b788dd14cc9823cadc0e
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Apr 17 09:54:30 2026 +0200
    Put ST_Azimuth tests in its own file
diff --git a/regress/core/azimuth.sql b/regress/core/azimuth.sql
new file mode 100644
index 000000000..2e2977413
--- /dev/null
+++ b/regress/core/azimuth.sql
@@ -0,0 +1,57 @@
+--- ST_Azimuth
+SELECT 'ST_Azimuth_regular' , round(ST_Azimuth(geom1,geom2)::numeric,4)
+FROM CAST('POINT(0 1)' AS geometry) AS geom1, CAST('POINT(1 0)' AS geometry) AS geom2 ;
+SELECT 'ST_Azimuth_same_point' , ST_Azimuth(geom1,geom1)
+FROM CAST('POINT(0 1)' AS geometry) AS geom1 ;
+SELECT 'ST_Azimuth_mixed_srid' , ST_Azimuth(geom1,geom2)
+FROM CAST('POINT(0 1)' AS geometry) AS geom1, ST_GeomFromText('POINT(1 0)',4326) AS geom2;
+SELECT 'ST_Azimuth_not_point' , ST_Azimuth(geom1,geom2)
+FROM CAST('POINT(0 1)' AS geometry) AS geom1, ST_GeomFromText('LINESTRING(1 0 ,2 0)',4326) AS geom2;
+SELECT 'ST_Azimuth_null_geom' , ST_Azimuth(geom1,geom2)
+FROM CAST('POINT(0 1)' AS geometry) AS geom1, ST_GeomFromText('EMPTY') AS geom2;
+-- #1305
+SELECT '#1305.1',ST_AsText(ST_Project('POINT(10 10)'::geography, 0, 0));
+WITH pts AS ( SELECT 'POINT(0 45)'::geography AS s, 'POINT(45 45)'::geography AS e )
+SELECT '#1305.2',abs(ST_Distance(e, ST_Project(s, ST_Distance(s, e), ST_Azimuth(s, e)))) < 0.001 FROM pts;
+SELECT '#1305.3',ST_Azimuth('POINT(0 45)'::geography, 'POINT(0 45)'::geography) IS NULL;
+-- #1791 --
+with inp as ( SELECT
+ '010100000000000000004065C0041AD965BE5554C0'::geometry as a,
+ '010100000001000000004065C0041AD965BE5554C0'::geometry as b
+) SELECT '#1791', round(ST_Azimuth(a,b)*10)/10 from inp;
+SELECT '#4718',
+	round(degrees(
+	ST_Azimuth('POINT(77.46412 37.96999)'::geography,
+           'POINT(77.46409 37.96999)'::geography
+           ))::numeric,3),
+	round(degrees(
+           'POINT(77.46429 37.96999)'::geography
+           ))::numeric,3);
+SELECT
+'#4840',
+round(degrees(ST_azimuth(C,N)))  AS az_n,
+round(degrees(ST_azimuth(C,NE))) AS az_ne,
+round(degrees(ST_azimuth(C,E)))  AS az_e,
+round(degrees(ST_azimuth(C,SE))) AS az_se,
+round(degrees(ST_azimuth(C,S)))  AS az_s,
+round(degrees(ST_azimuth(C,SW))) AS az_sw,
+round(degrees(ST_azimuth(C,W)))  AS az_w,
+round(degrees(ST_azimuth(C,NW))) AS az_nw
+FROM (SELECT
+'POINT(5 55)'::geography AS C,
+'POINT(5 56)'::geography AS N,
+'POINT(6 56)'::geography AS NE,
+'POINT(6 55)'::geography AS E,
+'POINT(6 54)'::geography AS SE,
+'POINT(5 54)'::geography AS S,
+'POINT(4 54)'::geography AS SW,
+'POINT(4 55)'::geography AS W,
+'POINT(4 56)'::geography AS NW ) points;
diff --git a/regress/core/azimuth_expected b/regress/core/azimuth_expected
index 000000000..c24002591
--- /dev/null
+++ b/regress/core/azimuth_expected
@@ -0,0 +1,11 @@
+ST_Azimuth_regular|2.3562
+ST_Azimuth_same_point|
+ERROR:  Operation on mixed SRID geometries
+ERROR:  Argument must be POINT geometries
+ERROR:  parse error - invalid geometry
+#1305.1|POINT(10 10)
+#1305.2|t
+#1305.3|t
+#1791|4.7
+#4718|270.000|90.000
+#4840|0|29|90|149|180|211|270|331
diff --git a/regress/core/lwgeom_regress.sql b/regress/core/lwgeom_regress.sql
index c31487c30..3c647e3c8 100644
--- a/regress/core/lwgeom_regress.sql
+++ b/regress/core/lwgeom_regress.sql
@@ -155,18 +155,6 @@ SELECT 'BoundingDiagonal7.1', ST_AsEwkt(ST_BoundingDiagonal(postgis_addbbox('SRI
 SELECT 'BoundingDiagonal7.2', ST_AsEwkt(ST_BoundingDiagonal('SRID=3857;MULTILINESTRING Z ((5 4 0,4 4 1))'::geometry));
 SELECT 'BoundingDiagonal7.3', ST_AsEwkt(ST_BoundingDiagonal(postgis_addbbox('SRID=3857;MULTILINESTRING Z ((5 4 0,4 4 1))'::geometry)));
---- ST_Azimuth
-SELECT 'ST_Azimuth_regular' , round(ST_Azimuth(geom1,geom2)::numeric,4)
-FROM CAST('POINT(0 1)' AS geometry) AS geom1, CAST('POINT(1 0)' AS geometry) AS geom2 ;
-SELECT 'ST_Azimuth_same_point' , ST_Azimuth(geom1,geom1)
-FROM CAST('POINT(0 1)' AS geometry) AS geom1 ;
-SELECT 'ST_Azimuth_mixed_srid' , ST_Azimuth(geom1,geom2)
-FROM CAST('POINT(0 1)' AS geometry) AS geom1, ST_GeomFromText('POINT(1 0)',4326) AS geom2;
-SELECT 'ST_Azimuth_not_point' , ST_Azimuth(geom1,geom2)
-FROM CAST('POINT(0 1)' AS geometry) AS geom1, ST_GeomFromText('LINESTRING(1 0 ,2 0)',4326) AS geom2;
-SELECT 'ST_Azimuth_null_geom' , ST_Azimuth(geom1,geom2)
-FROM CAST('POINT(0 1)' AS geometry) AS geom1, ST_GeomFromText('EMPTY') AS geom2;
 --- ST_Angle(points)
 SELECT 'ST_Angle_4_pts', St_Angle(p1,p2,p3,p4)::numeric(12,6)
 	FROM ST_GeomFromtext('POINT(0 1)') AS p1, ST_GeomFromtext('POINT(0 0)') AS p2
diff --git a/regress/core/lwgeom_regress_expected b/regress/core/lwgeom_regress_expected
index dc3a70ecc..8239d0fec 100644
--- a/regress/core/lwgeom_regress_expected
+++ b/regress/core/lwgeom_regress_expected
@@ -42,11 +42,6 @@ BoundingDiagonal7  |SRID=3857;LINESTRINGM(4 4 0,5 4 1)
 BoundingDiagonal7.1|SRID=3857;LINESTRINGM(4 4 0,5 4 1)
 BoundingDiagonal7.2|SRID=3857;LINESTRING(4 4 0,5 4 1)
 BoundingDiagonal7.3|SRID=3857;LINESTRING(4 4 0,5 4 1)
-ST_Azimuth_regular|2.3562
-ST_Azimuth_same_point|
-ERROR:  Operation on mixed SRID geometries
-ERROR:  Argument must be POINT geometries
-ERROR:  parse error - invalid geometry
 ST_Angle_4_pts|4.712389
 ST_Angle_4_pts|0.785398
 ST_Angle_3_pts|1.570796
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index fc998a755..5e334ee5e 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -29,6 +29,7 @@ RUNTESTFLAGS_INTERNAL += \
 TESTS += \
 	$(top_srcdir)/regress/core/affine \
+	$(top_srcdir)/regress/core/azimuth \
 	$(top_srcdir)/regress/core/bestsrid \
 	$(top_srcdir)/regress/core/binary \
 	$(top_srcdir)/regress/core/boundary \
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 4c1fcb862..1dd8f2e98 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -489,12 +489,6 @@ SELECT '#657.1',Round(ST_X(ST_Project('POINT(175 10)'::geography, 2000000, 3.141
 SELECT '#657.2',Round(ST_Distance(ST_Project('POINT(10 10)'::geography, 10, 0), 'POINT(10 10)'::geography)::numeric,2);
 SELECT '#657.3',ST_DWithin(ST_Project('POINT(10 10)'::geography, 2000, pi()/2), 'POINT(10 10)'::geography, 2000);
--- #1305
-SELECT '#1305.1',ST_AsText(ST_Project('POINT(10 10)'::geography, 0, 0));
-WITH pts AS ( SELECT 'POINT(0 45)'::geography AS s, 'POINT(45 45)'::geography AS e )
-SELECT '#1305.2',abs(ST_Distance(e, ST_Project(s, ST_Distance(s, e), ST_Azimuth(s, e)))) < 0.001 FROM pts;
-SELECT '#1305.3',ST_Azimuth('POINT(0 45)'::geography, 'POINT(0 45)'::geography) IS NULL;
 -- #1445
 SELECT '01060000400200000001040000400100000001010000400000000000000000000000000000000000000000000000000101000040000000000000F03F000000000000F03F000000000000F03F'::geometry;
 SELECT '01050000400200000001040000400100000001010000400000000000000000000000000000000000000000000000000101000040000000000000F03F000000000000F03F000000000000F03F'::geometry;
@@ -679,12 +673,6 @@ FROM inp;
 -- #1780 --
 SELECT '#1780',ST_GeoHash('POINT(4 4)'::geometry) = ST_GeoHash('POINT(4 4)'::geography);
--- #1791 --
-with inp as ( SELECT
- '010100000000000000004065C0041AD965BE5554C0'::geometry as a,
- '010100000001000000004065C0041AD965BE5554C0'::geometry as b
-) SELECT '#1791', round(ST_Azimuth(a,b)*10)/10 from inp;
 -- #1799 --
 SELECT '#1799', ST_Segmentize('LINESTRING(0 0, 10 0)'::geometry, 0);
@@ -1343,16 +1331,6 @@ SELECT '#4689', _ST_DistanceTree('POLYGON ((30 10, 40 40, 20 40, 30 10))'::geogr
 SELECT '#4748', ST_AsEWKT(ST_Transform(ST_SetSRID(ST_Point(-36.75, -54.25), 4326), 3031),1);
 SELECT '#4842', ST_AsEWKT(ST_Transform(ST_SetSRID(ST_Point(12.572, 66.081), 4326), 3413),1);
-SELECT '#4718',
-	round(degrees(
-	ST_Azimuth('POINT(77.46412 37.96999)'::geography,
-           'POINT(77.46409 37.96999)'::geography
-           ))::numeric,3),
-	round(degrees(
-           'POINT(77.46429 37.96999)'::geography
-           ))::numeric,3);
 SELECT '#4727', _ST_DistanceTree('SRID=4326;POLYGON((-179.9 -85.05112877980659, -179.9 74.99999999999997, -152 80, -130 84.99999999999997, -115 85.05112877980659, -60 85.05112877980659, -60 79, -70 70, -130 50, -80 6, -65 -53, -100 -85.05112877980659, -179.9 -85.05112877980659))'::geography,
 				ST_MakePoint(-150,-40), 0.0, true);
@@ -1360,27 +1338,6 @@ SELECT '#4796', st_astext(st_snaptogrid(st_normalize(st_simplifypreservetopology
 SELECT '#4812', st_srid('SRID=999999;POINT(1 1)'::geometry);
-SELECT
-'#4840',
-round(degrees(ST_azimuth(C,N)))  AS az_n,
-round(degrees(ST_azimuth(C,NE))) AS az_ne,
-round(degrees(ST_azimuth(C,E)))  AS az_e,
-round(degrees(ST_azimuth(C,SE))) AS az_se,
-round(degrees(ST_azimuth(C,S)))  AS az_s,
-round(degrees(ST_azimuth(C,SW))) AS az_sw,
-round(degrees(ST_azimuth(C,W)))  AS az_w,
-round(degrees(ST_azimuth(C,NW))) AS az_nw
-FROM (SELECT
-'POINT(5 55)'::geography AS C,
-'POINT(5 56)'::geography AS N,
-'POINT(6 56)'::geography AS NE,
-'POINT(6 55)'::geography AS E,
-'POINT(6 54)'::geography AS SE,
-'POINT(5 54)'::geography AS S,
-'POINT(4 54)'::geography AS SW,
-'POINT(4 55)'::geography AS W,
-'POINT(4 56)'::geography AS NW ) points;
 SELECT '#4853', ST_ClusterDBSCAN(geom,  eps := 0.000906495804256269, minpoints := 4) OVER() AS cid FROM (VALUES ('0101000020E6100000E4141DC9E5934B40D235936FB6193940'::geometry), ('0101000020E6100000C746205ED7934B40191C25AFCE193940'::geometry), ('0101000020E6100000C780ECF5EE934B40B6BE4868CB193940'::geometry), ('0101000020E6100000ABB2EF8AE0934B404451A04FE4193940'::geometry)) AS t(geom);
 SELECT '#4844', ST_AsEWKT(ST_SnapToGrid(ST_Transform('SRID=3575;POINT(370182.35945313 -2213980.8213281)'::geometry,4326),0.001));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index b8b5e345c..c6185f24e 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -167,9 +167,6 @@ NOTICE:  Coordinate values were coerced into range [-180 -90, 180 90] for GEOGRA
 #657.1|-166.78
 #657.2|10.00
 #657.3|t
-#1305.1|POINT(10 10)
-#1305.2|t
-#1305.3|t
 ERROR:  MultiPolygon cannot contain MultiPoint element at character 8
 ERROR:  MultiLineString cannot contain MultiPoint element at character 8
 ERROR:  MultiPoint cannot contain MultiPoint element at character 8
@@ -218,7 +215,6 @@ NOTICE:  SRID value -1 converted to the officially unknown SRID value 0
 #1755|01e9030000000000000040554000000000008041400000000000000000
 #1776|POLYGON((0 0,10 0,10 10,0 0))|POLYGON((0 0,10 0,10 10,0 0))
 #1780|t
-#1791|4.7
 ERROR:  ST_Segmentize: invalid max_distance 0 (must be >= 0)
 ERROR:  invalid GML representation
 #1957|1
@@ -439,11 +435,9 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4689|0
 #4748|SRID=3031;POINT(-2399498.7 3213318.5)
 #4842|SRID=3413;POINT(2218086.2 -1409161.3)
-#4718|270.000|90.000
 #4727|0
 #4796|POLYGON((178632 397744,178738 397769,178745 397741,178749 397742,178752 397727,178748 397726,178759 397684,178699 397669,178694 397691,178646 397680,178632 397744))
 #4812|999999
-#4840|0|29|90|149|180|211|270|331
 #4853|0
 #4853|0
 #4853|0
Summary of changes:
 regress/core/azimuth.sql             | 57 ++++++++++++++++++++++++++++++++++++
 regress/core/azimuth_expected        | 11 +++++++
 regress/core/lwgeom_regress.sql      | 12 --------
 regress/core/lwgeom_regress_expected |  5 ----
 regress/core/tests.mk.in             |  1 +
 regress/core/tickets.sql             | 43 ---------------------------
 regress/core/tickets_expected        |  6 ----
 7 files changed, 69 insertions(+), 66 deletions(-)
 create mode 100644 regress/core/azimuth.sql
 create mode 100644 regress/core/azimuth_expected
hooks/post-receive
