[SCM] PostGIS branch master updated. 3.6.0rc2-469-gbb1a71e15
Fri Apr 17 00:38:05 PDT 2026
the project "PostGIS".
       via  bb1a71e15fdece2cab099682be270683b529cbc9 (commit)
      from  123d1687331c22066c5e8c901e5a2c7cd46c0ba8 (commit)
revisions in full, below.
commit bb1a71e15fdece2cab099682be270683b529cbc9
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Apr 17 09:37:46 2026 +0200
    Reduce polygon construction when all we need is CCW detection of ring
diff --git a/liblwgeom/topo/liblwgeom_topo.h b/liblwgeom/topo/liblwgeom_topo.h
index d3e3cd133..fb25c3a10 100644
--- a/liblwgeom/topo/liblwgeom_topo.h
+++ b/liblwgeom/topo/liblwgeom_topo.h
@@ -1430,6 +1430,6 @@ int lwt_GetFaceEdges(LWT_TOPOLOGY* topo, LWT_ELEMID face, LWT_ELEMID **edges);
 LWGEOM* lwt_GetFaceGeometry(LWT_TOPOLOGY* topo, LWT_ELEMID face);
-int lwt_IsTopoRingCCW(const LWGEOM *geom);
+int lwt_IsTopoRingCCW(const POINTARRAY *pa);
 #endif /* LIBLWGEOM_TOPO_H */
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 584b4d210..6d0144bb9 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -1881,10 +1881,8 @@ _lwt_GetInteriorEdgePoint(const LWLINE* edge, POINT2D* ip)
 int
-lwt_IsTopoRingCCW(const LWGEOM *lwg)
+lwt_IsTopoRingCCW(const POINTARRAY *pa)
-  LWPOLY *poly = lwgeom_as_lwpoly(lwg);
-  POINTARRAY *pa;
   const POINT2D *P1;
   const POINT2D *P2;
   const POINT2D *P3;
@@ -1894,11 +1892,6 @@ lwt_IsTopoRingCCW(const LWGEOM *lwg)
   uint32_t i;
   int ret;
-  if ( ! poly ) return 0;
-  if ( ! poly->nrings ) return 0;
-  pa = poly->rings[0];
   if (! pa || pa->npoints < 3 )
     return 0;
@@ -2048,6 +2041,8 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
     return NULL;
+  *isccw = lwt_IsTopoRingCCW(full_ring_pa);
   POINTARRAY **points = lwalloc(sizeof(POINTARRAY*));
   points[0] = full_ring_pa;
@@ -2056,8 +2051,6 @@ _lwt_MakeRingShell(LWT_TOPOLOGY *topo, LWT_ELEMID *signed_edge_ids, uint64_t num
   LWPOLY* shell = lwpoly_construct(0, 0, 1, points);
-  *isccw = lwt_IsTopoRingCCW(lwpoly_as_lwgeom(shell));
   return shell;
diff --git a/topology/postgis_topology.c b/topology/postgis_topology.c
index 769cececb..0599fc010 100644
--- a/topology/postgis_topology.c
+++ b/topology/postgis_topology.c
@@ -5828,10 +5828,31 @@ Datum TopoRingIsCCW(PG_FUNCTION_ARGS)
   GSERIALIZED *geom;
   LWGEOM *lwgeom;
   int isCCW;
+  const POINTARRAY *pa;
   geom = PG_GETARG_GSERIALIZED_P(0);
   lwgeom = lwgeom_from_gserialized(geom);
-  isCCW = lwt_IsTopoRingCCW(lwgeom);
+  if ( lwgeom_is_empty(lwgeom) )
+    PG_RETURN_BOOL(false);
+  if (lwgeom->type == POLYGONTYPE)
+    pa = ((const LWPOLY *)lwgeom)->rings[0];
+  else if (lwgeom->type == LINETYPE)
+    pa = ((const LWLINE *)lwgeom)->points;
+  else
+    lwpgerror("Unsupported geometry type passed to TopoRingIsCCW");
+    PG_RETURN_NULL();
+  isCCW = lwt_IsTopoRingCCW(pa);
   lwgeom_free(lwgeom);
   PG_FREE_IF_COPY(geom, 0);
diff --git a/topology/sql/manage/ValidateTopology.sql.in b/topology/sql/manage/ValidateTopology.sql.in
index 08ccd06f5..fb6f23c02 100644
--- a/topology/sql/manage/ValidateTopology.sql.in
+++ b/topology/sql/manage/ValidateTopology.sql.in
@@ -394,7 +394,6 @@ $BODY$
 DECLARE
   retrec topology.ValidateTopology_ReturnType;
   rec RECORD;
-  ring_poly GEOMETRY;
   is_shell BOOLEAN;
   found_rings INT := 0;
   found_shells INT := 0;
@@ -553,8 +552,7 @@ BEGIN
     IF ST_NPoints(rec.ring_geom) > 3 AND
        rec.num_edges != rec.distinct_edges * 2
     THEN
-      ring_poly := ST_MakePolygon(rec.ring_geom);
-      is_shell := topology.TopoRingIsCCW(ring_poly);
+      is_shell := topology.TopoRingIsCCW(rec.ring_geom);
     END IF;
 #ifdef POSTGIS_TOPOLOGY_DEBUG
@@ -571,7 +569,7 @@ BEGIN
       BEGIN
         INSERT INTO shell_check VALUES (
           rec.side_faces[1],
-          ring_poly
+          ST_MakePolygon(rec.ring_geom)
         found_shells := found_shells + 1;
       EXCEPTION WHEN unique_violation THEN
Summary of changes:
 liblwgeom/topo/liblwgeom_topo.h             |  2 +-
 liblwgeom/topo/lwgeom_topo.c                | 13 +++----------
 topology/postgis_topology.c                 | 23 ++++++++++++++++++++++-
 topology/sql/manage/ValidateTopology.sql.in |  6 ++----
 4 files changed, 28 insertions(+), 16 deletions(-)
hooks/post-receive
