AW: AW: AW: [postgis-users] PostGIS compiling error
Tyler Mitchell TMitchell at lignum.com
Fri Aug 8 09:23:00 PDT 2003
You'll need to run ./autogen.sh before configuring.
It would be good to have this install note added to the geos /INSTALL file.
Tyler
postgis-users-bounces at postgis.refractions.net wrote on 08/08/2003 10:02:08
AM:
> Paul,
> There is a problem with the tar you send me. The file
> source/examples/Makefile.in is missing. I'm not able to run configure.
> Horst
> -----Ursprüngliche Nachricht-----
> Von: Paul Ramsey [mailto:pramsey at refractions.net]
> Gesendet am: Freitag, 8. August 2003 16:23
> An: PostGIS Users Discussion
> Betreff: Re: AW: AW: [postgis-users] PostGIS compiling error
> Good idea...
> P.
> Düster Horst wrote:
> > Paul,
> > I only pulled postgis-cvs. Should I pull geos-cvs also? Please send me
a
> new
> > geos-cvs.ta.gz due to I can't connect to geos cvs. It would be great
you
> may
> > publish a nightly build or something else at the geos page.
> > Horst
> > Gesendet am: Freitag, 8. August 2003 16:12
> > Betreff: Re: AW: [postgis-users] PostGIS compiling error
> > All the latest CVS pulls? I just did a pull and things which were
broken
> > ceased to be.
> > P.
> > Düster Horst wrote:
> >>Ok I forgot to say that geos is installed under /usr/local/lib and
> >>/usr/local/include/geos
> >>Horst
> >>Von: Düster Horst [mailto:Horst.Duester at bd.so.ch]
> >>Gesendet am: Freitag, 8. August 2003 08:38
> >>An: 'postgis-users at postgis.refractions.net'
> >>Betreff: [postgis-users] PostGIS compiling error
> >>The compilation process of postgis-cvs crashes with the following error
> >>message:
> >>postgis_geos_wrapper.cpp:16: namespace `geos' undeclared
> >>What's the reason?? Any hint??
> >>Regards
> >>Horst
> >>Mit freundlichen Grüssen
> >>Dr. Horst Düster
> >>Leiter
> >>Abteilung SO!GIS Koordination
> >>Rötihof
> >>4500 Solothurn
> >>Tel.: 032 627 25 32
> >>Fax: 032 627 22 14
> >>horst.duester at bd.so.ch <mailto:horst.duester at bd.so.ch>
> >> <http://www.sogis.so.ch/> www.sogis.so.ch
> >>_______________________________________________
> >>postgis-users mailing list
> >>http://postgis.refractions.net/mailman/listinfo/postgis-users
>        __
>       | Paul Ramsey
>       | Refractions Research
>       | Email: pramsey at refractions.net
>       | Phone: (250) 885-0632
>       \_
