[postgis-users] itemnquery limitation
Zamil Murji
Zamil.Murji at divestco.com
Fri Aug 8 10:45:02 PDT 2003
I fixed the query for larger datasets as per the last email. No need to pg_dump the table.
It is definetely in the processing of the data that something goes wonky.
Zamil
-----Original Message-----
From: David Blasby [mailto:dblasby at refractions.net]
Sent: Friday, August 08, 2003 11:40 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] itemnquery limitation
Zamil Murji wrote:
> WHAT?? That can't be good. What do you think I did wrong. For a smaller subset of the data (ie. a select that that worked) this is what I got:
No - thats not good.
> Exactly what I expected to get back...What have i done wrong? The query seems to fail on larger record sets. What can I do to trace this error?
Its difficult to debug this. But if you pg_dump your table and send it
to me I can run it here and fix the problem.
dave
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
