Roman Meier wrote: > --> msDrawMap(): Image handling error. Failed to draw layer named > 'great_lakes'. This sounds like you're using the mapserver 4.0 that "eats" error messages. This is probably a mapserver->posgresql connection problem - is your connection information correct? Is the postgresql server setup to accept TCP/IP connections? dave
