[postgis-users] Help please
Zamil Murji
Zamil.Murji at divestco.com
Wed Aug 13 10:03:05 PDT 2003
Yeah, it works from the commandline.
I am running apache version 2.0.x (don't know what the x is) on a red hat 7.3 machine. I am trying to upgrade to version 2.0.47. What version are you testing on? Can you send me your httpd.conf file so that I may diff it against mine (the only thing different should be the server specific info)
Thanks
Zamil
-----Original Message-----
From: Dave Blasby [mailto:dblasby at refractions.net]
Sent: Wednesday, August 13, 2003 12:51 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Help please
> Funny thing, when I edit the source code and recompile, I will get less
> records brought back (say 5). All that I added was some print statements.
> Also it doesn't freeze at the same place in the code everytime. If I add some
> print statements, it might go so far. If I take out some print statements it
> dies somewhere else.
So, if you run your modified program from the command line, does it still work?
Mine works from the command line and through the web. What kind of webserver
do you have?
dave
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
