[postgis-users] Help please
Zamil Murji
Zamil.Murji at divestco.com
Wed Aug 13 10:13:18 PDT 2003
No I haven't tried that out. How can I see what user my web server runs as (i thought it was the user nobody but maybe i'm wrong). How can I set environment variables when starting the apache web server?
Thanks
Zamil
-----Original Message-----
From: Daniel Morissette [mailto:morissette at dmsolutions.ca]
Sent: Wednesday, August 13, 2003 11:08 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Help please
Zamil Murji wrote:
> I am running apache version 2.0.x (don't know what the x is) on a red hat 7.3 machine. I am trying to upgrade to version 2.0.47. What version are you testing on? Can you send me your httpd.conf file so that I may diff it against mine (the only thing different should be the server specific info)
Have you tried running at the command line as user apache (or whatever
user your httpd uses)? Maybe the bug is triggered by a file permission
issue. Also make sure that if you have a LD_LIBRARY_PATH set that it is
set to the same value in the web server and at the command line when you
do your tests.
Daniel Morissette morissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
