[postgis-users] "value out of range: underflow" blocking error
Marco Boeringa
marco at boeringa.demon.nl
Wed Feb 9 23:08:22 PST 2022
Hi Regina,
This was over-optimistic.
I now again see the "value out of range: underflow" error. However, this
now happened after upgrade of PROJ 6.3.1 to 8.2.0. Note that last time,
I also did this upgrade, as it was a forced and automatic one suggested
by the Ubuntu "Software Updater". So in both cases after restoring my
VM, this update from PROJ 6.3.1 to 8.2.0 happened before the issue
started appearing. So it appears the issue is related to the PROJ
update, not the GEOS update as I initially suspected.
One interesting thing I noted, is that the postgis_full_version still
shows 'PROJ="6.3.1"', instead of 8.2.0, despite the Synaptic Package
Manager clearly showing only 8.2.0 is installed:
PostGIS version: POSTGIS="3.2.0 c3e3cc0" [EXTENSION] PGSQL="130" GEOS="3.10.1-CAPI-1.16.0" PROJ="6.3.1" LIBXML="2.9.10" LIBJSON="0.13.1" LIBPROTOBUF="1.3.3" WAGYU="0.5.0 (Internal)"
Now I remember a similar issue with outdated version number for GEOS
from last year when I attempted to update GEOS from 3.6.0 to 3.8.0,
where Paul remarked something like that it meant that my PostGIS "wasn't
compiled with GEOS 3.8.0 support", so does this possibly also mean my
current PostGIS 3.2.0 installed from the official Ubuntu repository is
also not compiled with PROJ 8.2.0 support, and I should downgrade to 6.3.1?
Marco
Op 9-2-2022 om 12:57 schreef Marco Boeringa:
> Hi Regina,
> After restoring my VM a second time, I dug a little deeper into the
> problem, and I now think I understand what went wrong:
> I had initially attempted to upgrade my GEOS 3.8.0 that comes by
> default in the Ubuntu 20.04 install to GEOS 3.10.1 from the
> 'ubuntugis-unstable' PPA.
> To do this, after adding the PPA in Ubuntu, I checked the
> 'libgeos3.10.1' entry in the Synaptic Package Manager, and clicked
> "Apply". This succeeded, but I did not uninstall 'libgeos3.8.0' in the
> same process, so I had two 'libgeos' versions installed.
> This seems to have caused the issue, as after I now uninstalled
> 'libgeos3.8.0', I noticed the Synaptic Package manager updated a
> couple of dependent libraries to the 3.10.1 version:
> 'libgeos++dev','libgeos-c1v5','libgeos-dev'. So I guess the issue with
> the underflow was caused by having the outdated 3.8.0 versions of
> these libraries still installed.
> Marco
> Op 8-2-2022 om 19:23 schreef Regina Obe:
>> You have the create table statement we can test with?
>>> -----Original Message-----
>>> From: postgis-users [mailto:postgis-users-bounces at lists.osgeo.org] On
>>> Behalf Of Marco Boeringa
>>> Sent: Monday, February 7, 2022 2:34 PM
>>> To: postgis-users at lists.osgeo.org
>>> Subject: Re: [postgis-users] "value out of range: underflow" blocking
>> error
>>> One additional remark: in my case, there is no involvement of a GiST
>>> index
>> as
>>> per the PostgresPro link. It fails in a "CREATE TABLE" type
>>> statement that
>> also
>>> includes some calculations, so there isn't any indexes yet at that
>>> stage.
>>> Op 7-2-2022 om 08:17 schreef Marco Boeringa:
>>>> Hi,
>>>> Anyone else seeing this issue pop up, possibly after a recent update
>>>> to a PostgreSQL related component, or something that PostgreSQL /
>>>> PostGIS is dependent on?
>>>> I am still not sure if it is caused by something in my own coding, and
>>>> I first though this might be related to an attempt to upgrade to
>>>> PostgreSQL 14, but after restoring my machine to PostgreSQL 13(.5), I
>>>> still see this error blocking the successful execution of a crucial
>>>> query in my toolchain, that used to run fine up until recently.
>>>> I noticed there has been some very recent discussion about this same
>>>> type of error on a PostgreSQL mailing list:
>>>> https://postgrespro.ru/list/thread-id/2580248
>>>> Marco
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20220210/0a32eb6d/attachment.html>
