[QGIS-Developer] Server and authentication tests not running on Travis
Alessandro Pasotti
apasotti at gmail.com
Fri Nov 3 09:06:30 PDT 2017
just to inform all devs that I've just discovered that all QGIS Server
tests + the vast majority of authentication system tests
+ some of the integration tests that require the server have not been
running on travis since last 4 october when the travis docker
configuration was merged .
If you have been relying on Travis for changes on QGIS Server, WFS provider
and Authentication system during the last month, please make sure you
re-run tests locally until the tests are reactivated on Travis.
Alessandro Pasotti
w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171103/6b489d06/attachment.html>
