[QGIS-Developer] all profile removed, still OWS connections, where stored?
Régis Haubourg
regis.haubourg at gmail.com
Wed Nov 29 05:33:58 PST 2017
Huh,
what is the rationale behind keeping a V2 file in QGIS3? Migrating fromr
QGIS2 shouldn't mean using the same files.
Régis
2017-11-29 14:20 GMT+01:00 Richard Duivenvoorde <rdmailings at duif.net>:
> On 29-11-17 13:51, Régis Haubourg wrote:
> > Hi,
> > we just realized that QGISCUSTOMIZATION2.conf is still used, it is not
> > creating a QGISCUSTOMIZATION3.conf.
> > I suppose it's a bug? Anyone confirms?
> > Régis
> Régis,
> Are you sure it is actually used or is it 'migrated'.
> What I found was that if I not remove:
> ~/.local/share/QGIS
> and from qgis2.18:
> ~/.qgis2
> ~/.config/QGIS <= this is in registry in Windows
> then I do not startup with a clean 3.0 sheet.
> You will also end up with svg-paths to 2.18 qgis paths.
> @nathan? would it not be nicer to ask a user if he wants to bring the
> qsettings from 2.x over to 3 or not? Only the first time this migration
> is done isn't it?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171129/51685e0b/attachment.html>
