[QGIS-Developer] all profile removed, still OWS connections, where stored?
Nathan Woodrow
madmanwoo at gmail.com
Wed Nov 29 05:54:23 PST 2017
There are no v2 files kept. If it's named the same it's just not updated in
the code. Settings are auto migrated from 2 to 3 into the new settings
files.
There will hopefully be a first run screen if I get time to implement it
before release.
@Richard for now make a new profile and run with that as the main one. The
default profile is always migrated to give users a nicer first-run
experience of 3 because losing all the settings sucks.
- Nathan
On Wed, Nov 29, 2017 at 11:33 PM, Régis Haubourg <regis.haubourg at gmail.com>
wrote:
> Huh,
> what is the rationale behind keeping a V2 file in QGIS3? Migrating fromr
> QGIS2 shouldn't mean using the same files.
> Régis
> 2017-11-29 14:20 GMT+01:00 Richard Duivenvoorde <rdmailings at duif.net>:
>> On 29-11-17 13:51, Régis Haubourg wrote:
>> > Hi,
>> > we just realized that QGISCUSTOMIZATION2.conf is still used, it is not
>> > creating a QGISCUSTOMIZATION3.conf.
>> > I suppose it's a bug? Anyone confirms?
>> > Régis
>> Régis,
>> Are you sure it is actually used or is it 'migrated'.
>> What I found was that if I not remove:
>> ~/.local/share/QGIS
>> and from qgis2.18:
>> ~/.qgis2
>> ~/.config/QGIS <= this is in registry in Windows
>> then I do not startup with a clean 3.0 sheet.
>> You will also end up with svg-paths to 2.18 qgis paths.
>> @nathan? would it not be nicer to ask a user if he wants to bring the
>> qsettings from 2.x over to 3 or not? Only the first time this migration
>> is done isn't it?
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171129/596c2b00/attachment.html>
