[QGIS-Developer] Save Log messages as pdf
Nathan Woodrow madmanwoo at gmail.com
Fri Jul 12 05:50:34 PDT 2019
Sure. You would be able to do this with a QPainter. Have a search for print
pdf using At and you should get something. We use the built on At libs to
render layout prints.
On Fri., 12 Jul. 2019, 10:44 pm Roberta Fagandini, <robifagandini at gmail.com>
wrote:
> Hi all,
> I'm working on a plugin that prints a report at the end of the process in
> a log text area of the GUI. I'd like to add an option (maybe a checkbox) to
> save the content of the log and the image of the map area as a single
> multipage pdf file.
> Is it possible with the standard libraries or it requires external
> dependencies? Do you have any documentation to suggest?
> Thanks in advance
> Roberta
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190712/b9a398e8/attachment.html>
More information about the QGIS-Developer mailing list
