[QGIS-Developer] Save Log messages as pdf
Roberta Fagandini
robifagandini at gmail.com
Fri Jul 12 06:14:10 PDT 2019
Thank you Nathan,
I found some documentation about QPainter but I'm not able to find
something interesting about At lib..do you have any specific link?
Using the solution that you suggested, is it possible to set graphic
effects? for instance bold or italic characters, font size, text spacing
and justification, ecc.
Thank you!
Roberta
Il giorno ven 12 lug 2019 alle ore 14:50 Nathan Woodrow <madmanwoo at gmail.com>
ha scritto:
> Sure. You would be able to do this with a QPainter. Have a search for
> print pdf using At and you should get something. We use the built on At
> libs to render layout prints.
> On Fri., 12 Jul. 2019, 10:44 pm Roberta Fagandini, <
> robifagandini at gmail.com> wrote:
>> Hi all,
>> I'm working on a plugin that prints a report at the end of the process in
>> a log text area of the GUI. I'd like to add an option (maybe a checkbox) to
>> save the content of the log and the image of the map area as a single
>> multipage pdf file.
>> Is it possible with the standard libraries or it requires external
>> dependencies? Do you have any documentation to suggest?
>> Thanks in advance
>> Roberta
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190712/64ba9113/attachment-0001.html>
