[QGIS-Developer] Save Log messages as pdf
Nathan Woodrow
madmanwoo at gmail.com
Fri Jul 12 06:20:37 PDT 2019
Sorry that should have been Qt libs. Phone auto correct doesn't understand
"Qt".
Here is a good example for you that should work out of the box. This is
C++ but it's the same logic for PyQt:
https://wiki.qt.io/Exporting_a_document_to_PDF
- Nathan
On Fri, Jul 12, 2019 at 11:14 PM Roberta Fagandini <robifagandini at gmail.com>
wrote:
> Thank you Nathan,
> I found some documentation about QPainter but I'm not able to find
> something interesting about At lib..do you have any specific link?
> Using the solution that you suggested, is it possible to set graphic
> effects? for instance bold or italic characters, font size, text spacing
> and justification, ecc.
> Thank you!
> Roberta
> Il giorno ven 12 lug 2019 alle ore 14:50 Nathan Woodrow <
> madmanwoo at gmail.com> ha scritto:
>> Sure. You would be able to do this with a QPainter. Have a search for
>> print pdf using At and you should get something. We use the built on At
>> libs to render layout prints.
>> On Fri., 12 Jul. 2019, 10:44 pm Roberta Fagandini, <
>> robifagandini at gmail.com> wrote:
>>> Hi all,
>>> I'm working on a plugin that prints a report at the end of the process
>>> in a log text area of the GUI. I'd like to add an option (maybe a checkbox)
>>> to save the content of the log and the image of the map area as a single
>>> multipage pdf file.
>>> Is it possible with the standard libraries or it requires external
>>> dependencies? Do you have any documentation to suggest?
>>> Thanks in advance
>>> Roberta
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190712/e26f92df/attachment.html>
