[QGIS-Developer] Save Log messages as pdf
Roberta Fagandini
robifagandini at gmail.com
Fri Jul 12 07:01:16 PDT 2019
Oh sorry, I should have understood that you meant Qt..
Thank you so much, Nathan! Your link seems to be exactly what I need.
Thanks again!
Roberta
Il giorno ven 12 lug 2019 alle ore 15:20 Nathan Woodrow <madmanwoo at gmail.com>
ha scritto:
> Sorry that should have been Qt libs. Phone auto correct doesn't
> understand "Qt".
> Here is a good example for you that should work out of the box. This is
> C++ but it's the same logic for PyQt:
> https://wiki.qt.io/Exporting_a_document_to_PDF
> - Nathan
> On Fri, Jul 12, 2019 at 11:14 PM Roberta Fagandini <
> robifagandini at gmail.com> wrote:
>> Thank you Nathan,
>> I found some documentation about QPainter but I'm not able to find
>> something interesting about At lib..do you have any specific link?
>> Using the solution that you suggested, is it possible to set graphic
>> effects? for instance bold or italic characters, font size, text spacing
>> and justification, ecc.
>> Thank you!
>> Roberta
>> Il giorno ven 12 lug 2019 alle ore 14:50 Nathan Woodrow <
>> madmanwoo at gmail.com> ha scritto:
>>> Sure. You would be able to do this with a QPainter. Have a search for
>>> print pdf using At and you should get something. We use the built on At
>>> libs to render layout prints.
>>> On Fri., 12 Jul. 2019, 10:44 pm Roberta Fagandini, <
>>>> Hi all,
>>>> I'm working on a plugin that prints a report at the end of the process
>>>> in a log text area of the GUI. I'd like to add an option (maybe a checkbox)
>>>> to save the content of the log and the image of the map area as a single
>>>> multipage pdf file.
>>>> Is it possible with the standard libraries or it requires external
>>>> dependencies? Do you have any documentation to suggest?
>>>> Thanks in advance
>>>> Roberta
>>>> _______________________________________________
>>>> QGIS-Developer mailing list
>>>> QGIS-Developer at lists.osgeo.org
>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190712/91adc190/attachment.html>
