[QGIS-Developer] Is the measurement tool using proj library?
C Hamilton adenaculture at gmail.com
Thu Jul 18 08:38:10 PDT 2019
Andreas,
How do your results compare with the "Shape Tools" measurement tool? It is
based on the geographiclib library.
Calvin
On Thu, Jul 18, 2019 at 10:38 AM Andreas Neumann <a.neumann at carto.net>
wrote:
> Hi,
> We are having issues on the QGIS 3.4 release that the difference between
> and ellipsoidical and planimetric distance (and area) is huge. Too huge.
> We have this issue on Windows 3.4.9, but on Linux (a bit newer commit) I
> don't have the same huge difference, but rather a very reasonable one.
> I noticed that while the Windows version was built with proj 520 and the
> Linux version with 493, so a bit older.
> But I don't know if the measurement tool in QGIS is using proj at all or
> not? If yes, could it be that newer proj releases made things worse
> regarding ellipsoidical measurements?
> Thanks,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190718/e1b2a01f/attachment-0001.html>
More information about the QGIS-Developer mailing list
