[QGIS-Developer] Crashes on exit
Mathieu Pellerin
nirvn.asia at gmail.com
Fri Jul 19 20:26:33 PDT 2019
Calvin,
A fair amount of crashers and stability issues have been resolved in 3.8.1,
which'll be out in a few days. Give that a try.
If you still find it unstable, actionable information describing crashes
and issues are needed (since you're a plugin dev, I'm sure that's familiar
to you ;) ). If a project file hangs QGIS, fill and issue with the project.
Same goes for the georefencer or other bugs you stumble on.
Best
On Thu, Jul 18, 2019, 22:45 C Hamilton <adenaculture at gmail.com> wrote:
> QGIS 3.8 crashes most times for me on exiting and I have also found it to
> be fairly unstable. I have had it corrupt one of the saved files so that
> when it tried to load it, it would just hang. The georeferencing almost
> always crashes or delivers strange results. I have not reported on it
> because I have not been able to come up with repeatable steps to cause it
> to crash, but the net result is I now am only using QGIS 3.4.9 for real
> work and 3.8 to play around. I am hoping that the next release will fix
> some of the reliability problems.
> Calvin
> On Thu, Jul 18, 2019 at 6:18 AM Nathan Woodrow <madmanwoo at gmail.com>
> wrote:
>> Thanks Jürgen,
>> Yeah I know it was a bit much to have them included. I will see what I
>> can do with my install and hopefully get a good stack trace.
>> Regards,
>> Nathan
>> On Thu, Jul 18, 2019 at 5:07 PM Jürgen E. Fischer <jef at norbit.de> wrote:
>>> Hi Nathan,
>>> On Thu, 18. Jul 2019 at 16:51:44 +1000, Nathan Woodrow wrote:
>>> > Jurgen, would we be able to include the debug symbols for the build on
>>> the
>>> > normal installers for once release cycle while this is still an issue?
>>> That
>>> > would be super handy to catch this and other issues that come up.
>>> You can already install the qgis-pdb package using the normal
>>> installer. The
>>> normal installer is also shipped with the standalone, so you could also
>>> use
>>> that to install pdbs afterwards. They cannot be included in the
>>> standalone as
>>> we're already near to NSIS' 2GB limit (maybe once the GRASS package is
>>> ported
>>> to python3, so we can drop all python2 - but I gues not as the pdbs are
>>> huge)
>>> We also have a symbol server - but given the nightlies it's huge and
>>> needs to
>>> be aged out quickly (a week I think) so the release symbols probably
>>> don't last
>>> long. Running nightlies for this kind of thing should help.
>>> Jürgen
>>> Jürgen E. Fischer norBIT GmbH Tel.
>>> +49-4931-918175-31
>>> Dipl.-Inf. (FH) Rheinstraße 13 Fax.
>>> +49-4931-918175-50
>>> Software Engineer D-26506 Norden
>>> https://www.norbit.de
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190720/e445a698/attachment.html>
