[postgis-tickets] [PostGIS] #3220: Mingw failure on cluster test
trac at osgeo.org
Fri Jul 31 06:17:36 PDT 2015
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment (by robe):
there is an order by. Test looks like this:
CREATE TEMPORARY TABLE cluster_inputs (id int, geom geometry);
INSERT INTO cluster_inputs VALUES
(1, 'LINESTRING (0 0, 1 1)'),
(2, 'LINESTRING (5 5, 4 4)'),
(3, NULL),
(4, 'LINESTRING (0 0, -1 -1)'),
(5, 'LINESTRING (6 6, 7 7)'),
(6, 'POLYGON EMPTY'),
(7, 'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))');
SELECT 't1', ST_AsText(unnest(ST_ClusterIntersecting(geom ORDER BY id)))
FROM cluster_inputs;
SELECT 't2', ST_AsText(unnest(ST_ClusterIntersecting(ST_Accum(geom ORDER
BY id)))) FROM cluster_inputs;
SELECT 't3', ST_AsText(unnest(ST_ClusterWithin(geom, 1.4 ORDER BY id)))
SELECT 't4', ST_AsText(unnest(ST_ClusterWithin(ST_Accum(geom ORDER BY id),
1.5))) FROM cluster_inputs;
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3220#comment:3>
