[SCM] PostGIS branch master updated. 3.6.0rc2-435-g2c9277d3d
git at osgeo.org
git at osgeo.org
Wed Apr 8 03:28:46 PDT 2026
the project "PostGIS".
via 2c9277d3da0794f44dee60107d107cfd9939edeb (commit)
from acc6afbd9212beaf8e2039c7f2369584a6c9ec77 (commit)
revisions in full, below.
commit 2c9277d3da0794f44dee60107d107cfd9939edeb
Author: Sandro Santilli <strk at kbt.io>
Date: Wed Apr 8 12:27:36 2026 +0200
Add topology test for ticket 6064
The test would fail if we reverted commit
7e3d523cda37faa3efdb8daed91e73df6a9fe864
Closes #6064
diff --git a/topology/test/regress/topogeo_addlinestring.sql b/topology/test/regress/topogeo_addlinestring.sql
index aadf897f6..f54145537 100644
--- a/topology/test/regress/topogeo_addlinestring.sql
+++ b/topology/test/regress/topogeo_addlinestring.sql
@@ -630,3 +630,26 @@ SELECT 't6062.edges', count(*) > 0 FROM topology.TopoGeo_addLinestring('t6062',
ORDER BY 2;
SELECT 't6062.2', 'error', * FROM topology.ValidateTopology('t6062') v;
SELECT NULL FROM topology.DropTopology ('t6062');
+-- See https://trac.osgeo.org/postgis/ticket/6064
+set client_min_messages to WARNING;
+SELECT NULL FROM topology.CreateTopology ('t6064');
+SELECT 't6064.1', count(*) > 0 FROM topology.TopoGeo_addLinestring('t6064',
+'LINESTRING(
+ 17.42207545158684 69.11091383590066,
+ 17.422075702665087 69.11091383235977,
+ 17.579930758184094 69.12294910230447
+ , 17.622976580401446 69.12848944101118
+SELECT 't6064.check.intermediate', * FROM topology.ValidateTopology('t6064');
+set client_min_messages to DEBUG;
+SELECT 't6064.2', count(*) > 0 FROM topology.TopoGeo_addLinestring('t6064',
+'LINESTRING(
+ 17.42207545158653 69.11091383590062,
+ 17.42207570266477 69.11091383235974,
+ 17.622976580401076 69.12848944101118
+SELECT 't6064.check.final', * FROM topology.ValidateTopology('t6064');
+SELECT NULL FROM topology.DropTopology ('t6064');
diff --git a/topology/test/regress/topogeo_addlinestring_expected b/topology/test/regress/topogeo_addlinestring_expected
index 5ef1bb81a..a698decff 100644
--- a/topology/test/regress/topogeo_addlinestring_expected
+++ b/topology/test/regress/topogeo_addlinestring_expected
@@ -234,3 +234,5 @@ ERROR: Adding line to topology requires creating more edges than the requested
t6023.1|errors|
t6023.2|errors|
t6062.edges|t
+t6064.1|t
+t6064.2|t
Summary of changes:
topology/test/regress/topogeo_addlinestring.sql | 23 ++++++++++++++++++++++
.../test/regress/topogeo_addlinestring_expected | 2 ++
2 files changed, 25 insertions(+)
hooks/post-receive
